Question about XION (XON-001) ATX Mid-Tower Case
MY printer will not work because of an Nt 4.0 drivers are blocked
  • XION Master
  • 27,725 Answers
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Posted on Apr 10, 2011
Testimonial: "Thank you for your help what I ended up doing was deleting the printer and I had to check an option for bidirectional communication option "
  • 4 more comments
  • hammer_famil Apr 10, 2011
    I will try that but I contacted Lexmark about my problem & they had trouble installing it on my computer as well so they probably don"t have any new drivers but who knows what it will find. thank you for your suggestion cause I've been getting a headache over this since it was working on my computer at one time. I was thinking however that when I set up my WiFi and sharing through my home that is what may have caused the block. Would or could that be a possibility as well??
  • Brian Sullivan
    Brian Sullivan Apr 10, 2011
    if you printer came with an installation disc the drivers will be on it and yes the WiFi and sharing may have corrupted the drivers all you might have to do is to reinstall the drivers hope this works for you and relieves your headache
    " Thank you for your help what I ended up doing was deleting the printer and I had to check an option for bidirectional communication option "
  • Brian Sullivan
    glad i could help and hope the headache has gone ha ha
    Well it's not gone yet ha ha but it's starting to go away.It took me hours & it was something so small & just taking the right steps I would not of been able to do it without the help. I was ready to go buy a new printer
  • Brian Sullivan
    thanks for the vote of support this makes me think its all worthwile
Printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Oct 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
Message saying "no connection between PC and printer. Installed new USB cable and it works for 2 weeks, then "no connection notice again". Uninstalled and reinstalled Dell printer software and no help.
hi jaromarburge,
you can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 12, 2009 | Dell 922 All-In-One InkJet Printer
Dell 926 does not print...."communications with computer and printer not present"....tried reinstalling driver....no luck....Jeff
hi jeffhup,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 11, 2009 | Dell 926 All-In-One InkJet Printer
Printer can't communicate with computer
Hi rcamp3,
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 05, 2009 | Dell 924 All-in-One InkJet Printer
Printer not printing
if your printer is giving you an error msg saying printer communication not available.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day :)
Oct 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
Scanner not working ... can't figure out why... need to scan my paycheck to deposit to bank but says scanner not connected (but it is) or not turned on (but it is) ... printer works fine, but scanner does...
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day. :)
Oct 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
My printer is not printing everything else works, computer says that the printer is not connected.
hi there,
have a great day :)
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
My Dell Photo Printer 720 has stopped printed, no response at all to print jobs. I have unplugged the printer, no change. I have rebooted the computer, no change.
hi there,
Aug 03, 2009 | Dell Inkjet 720 Printer
Dell 926 printer wont print text.
do you receive and error msg like printer communication not available?
if you're receiving printer communication not available, you can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day
Dec 23, 2008 | Dell 926 All-In-One InkJet Printer
XION (XON-001) ATX Mid-Tower Case Logo
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
shuyumeng
shuyumeng
Farokh Merek
Farokh Merek
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
