When i put in a new RW disk i get a message "no disk"
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 09, 2011
Display DVD recorder DVO-1000MD says "NO DISK" with correct disk
Has to be a DVD+RW for this type of player, have you got the correct sort of media disc?
Bob - www.woodenmen.co.uk
Feb 01, 2010 | Sony DW-G120A DVD RW Dual Layer Burner
D:not accessible,incorrect function
If you've used the Drive before, then one of two things is possible. First, your disk may not be formatted. If you're using Windows XP or Windows Vista, you can format the CD if it's a RW (re-writable) type disk.
If it's not an RW type disk then you must use a software package to burn the pics to the CD. Also, make sure the type and writing speed of the CD is compatible with your system. Some older CD writers won't use the Newer 8X type disks. You'll need the newer type to us that type disk. If you're using older disks with a newer driver, then go purchase new disks and try again.
To make sure the driver itself is working, put in a disk you purchased, which you know is good, and see if your drive can read it. If not, then the drive is bad.
Oct 09, 2009 | HP Computers & Internet
Get Error msg - RW CD is Read Only
OK for CD-RW you have to make sure you are using a burning application that allow's CD-RW. This is DIFFERENT to making a MULTISESSION disk whereby you can add file later.
If you use a CD-RW media and just burn normally, the application will finish off the disk as a CD-R media.
Basically, the disk must be 'formatted' correctly for CD-RW which will allow you to add/remove/modify the files on the CD.
Most versions of NERO should have this facility.
Mar 25, 2009 | HP Computers & Internet
Samsung make TSSTcorp CD/DVDW SH-S182F
on creation or compilation of any cd/dvd regardless of disk format or capacity. the finalizing of a disk. will write a TOC ( table Of Contents ) this will inform the drive reading the disk. whats on it. even if a cd or dvd writes 1 track of music. if thats all you put on the disk, and finalise it. that will be the finished capacity. if you use rw disks. you must format the disk before re-using it.
this will completely erase all previous data on it.
If as stated you are using Nero. there are setting options, to create a multi-session cd/dvd whereby you can add additional files at a later date. however this disk will not be readable, by any other computer-cd/dvd player. until the disk has been finalised, and produced the Table-Of-Contents. ( Index )
Mike @ Compurepair.
May 10, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd - rw
The full manual can be found here. http://support.toshiba.ca/support/ceg/manuals/#
Oct 28, 2007 | Toshiba D-R2 DVD Recorder
Laptop CD/DVD Drive
In order to copy files to a CD like a hard drive you need a program that can treat the CD like a hard drive. Sometimes called *drag and drop or drag to disk*, is this what you?re using and if so what program are you using?
Mar 31, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
