Question about Acer Computers & Internet
Hi, my acer aspire one d255-1549 won't power up. when i connect the charger, the red battery indicator light is on, still won't power up. i need help, thanks
    Master:
  • 341 Answers
Try booting from an operating system compact disk you used for installing the first operating system or any other operating system same as the one you were currently using
Posted on Apr 10, 2011
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Hi i have a acer aspire 5100-5674 laptop, i was using the computer when i saw the orange light meaning low battery, my computer was plugged in however... the next minute i know everything got turned off...
The first step is to check both the charger and the battery at a shop. If both are good then it could be a connector problem where the charger plugs in
Aug 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
Shut Down with message that battery power out. Was connected to AC via power supply at the time
When the ac adapter is plugged in does the charge light come on to indicate the battery is charging? If not, the charger has probably failed. Faulty battteries can also cause a charger to fail. Both need to be checked.
Dec 11, 2009 | Acer Aspire One PC Notebook
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
