Question about HP Deskjet 6940 InkJet Printer
Printing RAINBOW of colors!
My PC is set to print simple black text, but I the text prints in all colors of the rainbow. Started when I replaced the black cartridge with a new one. I have replaced the new one with a NEWER one, but the problem persists. All cartriges are genuine HP cartridges. Printer is just over 1 yr. old.
  • 876 Answers
Change the color cartridge and see what happens.
Posted on Aug 15, 2008
Printing a rainbow of color on the right side of pictures!
Check the linear encoder. Try to print without high speed option.
Jan 24, 2013 | Epson Expression Home XP-400 Color Inkjet...
Does printing black text only on a Brother Inkjet All-in-One (MFC-J625DW) use the color cartridges?
Your right. Simple answer. Take the coloured cartraiges out (you may need to set your printer to mono crome though. not sure.? Save a bit more money and recycle your cartrages you get paid for them. then you can buy refill cartrages and save even more. Some say do not use them they cause problems, but i have from day one and still have no problems 29 years later!!! and i am a high user on a A1 PRINTER!!! (draughtsman if your wondering)
Jan 25, 2012 | Office Equipment & Supplies
Why does my Epson Stylus NX300 print a rainbow color band at the bottom of vertical 4x6 pictures
DOES THIS COLOR SHOW UP ON YOUR PRINT PREVIEW?
IF NOT, THAN GO INTO PRINT CARTRIDGES ON YOUR COMPUTER AND CLEAN THEM UP!
THAN DO A TEST ON A SEPERATE PIECE OF PAPER THE SAME PICTURE TO MAKE SURE IT HAS STOPPED WITH THE RAINBOW PROBLEM YOU'RE HAVING.
YOU MAY ALSO HAVE PICTURE SETTINGS WRONG ON YOUR COMPUTER, YOU CAN CHECK THESE UNDER PRINT PREFERENCES.
IF NON OF THE ABOVE WORK, THAN TAKE YOUR PRINT CARTRIDGES OUT AND CLEAN THE CONTACTS WITH SOME RUBBING ALCOHOL AND A Q-TIP.
Aug 25, 2011 | Epson Stylus NX300 All-In-One InkJet...
Rainbow line across the middle of the page
Possible print alignment issue.
Check the toner and then go to properties of printer.
Clean heads etc and then print test page.
Wizard should assist to troubleshoot
Jul 13, 2009 | Samsung CLP-510 Laser Printer
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i550 has has rainbow line in output
Even though you say you have ink, the "rainbow" line is usually an ink problem. Try doing a head clean process.
Right-mouse click on the printer and bring up "Properties". There should be a 'Maintenance" tab and one or more cleaning options and/or nozzle checks.
Sep 05, 2008 | Canon BubbleJet i550 InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
"Rainbow" word art (Microsoft)
Have you tried prinitng this in MONO on your 2840 printer.
Does Wordart from Word or other office programs cause this?
If it is the office suite, then look at downloading some service packs from Microsoft.
If it's just your 2840 doing it, then look at downloading a different driver.
For some printers there are different types of PCL drivers, like PCL5 or PCL6, these do behave differently per printer, so swapping the driver might not be a bad idea.
Also check if you are using a PS or Postscript driver, but again, try the PCL alternative for your printer.
I would install the different driver under another name, for testing, then if it works just delete the bad one.
May 08, 2008 | HP Color LaserJet 2600n Printer
Unwanted color printing
assuming you are using a browser have you gone to file page setup and uncheck the background printing of colors.
otherwise we need more info
OS , software application used, usb /network printer ,model printer
any changes made recently. etc..
Apr 02, 2008 | Computers & Internet
HP Deskjet 6940 InkJet Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
