Question about Miele 24 in. G686SCi Plus Built-in Dishwasher
My Miele dishwasher Model 896SCI PLUS has Intakelight blinking 5 times. Only pump runs. What is it telling me and how do I fix it?
  • evgantz Apr 15, 2011
    Water collected in base. Remove kick panel and one behind it. Sponge out water.
  • 122 Answers
SOURCE: MIELE DISHWASHER PARTS
We would have to order one -
Mike
Posted on Jan 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
SOURCE: Miele dishwasher drying problem
Great advice, one build on the G646SC Plus; the 4 screws are the lower 2 screws either, on the stainless steel inside of the door
Posted on Jan 02, 2010
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
Miele G851SC Plus
time for a full system flush, including the lower part of your pumps..you ready for a three hour job, or do you want a local service guy to handle this?
Mar 24, 2008 | Miele 24 in. Novotronic G851SC Plus...
This dishwasher will drain but not wash m/n g811sci the intake drain lite is blinking
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Gene
Aug 05, 2011 | Miele G811SCI Dishwasher
After pressing start programme light goes off and it 'bleeps' all the time
I had a somewhat similar problem on my Miele G896SCI dishwasher. Here was the fix that worked, provided by phone by Miele.
1. Turn on at On/Off button. 2. Press and hold Start/Stop button until the red light blinks. 3. Press On/Off button to Off, then back On.
That reset the machine and it returned to normal operation for years
Apr 09, 2011 | Miele 24 in. G686SCi Plus Built-in...
Miele dw flashes 5 times, water is draining. Suspect filter/valve housing at end of water inlet line. Their is a wire running to this valv so I imagine whatever solenoid that tells the valve to open and...
which light is flashing? if the intake drain light is blinking and you dont hear the drain pump, it means water is not coming in. if the drain pump is running all the time, it means water has leaked into the bottom pan. behind the plastic toe kick, there is a panel that can be removed with two phillips head screws. It you can see water in there, you can dry it out, and try to run another cycle. if it runs fine, cut back on your detergent usage. if it leaks again within a cycle or two, you will need to locate the leak and repair.
Nov 18, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Miele 24 in. G686SCi Plus Built-in Dishwasher Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
