Question about Brother LX3125 Sewing Machine
I ran out of thread while sewing and now my machine won't run. Do you have any suggestions?
    Sergeant:
    Champion:
  • 207 Answers
Did u jam your thread in your bottom bobber you could have thread jamed..
Posted on Apr 09, 2011
Hi im trying to fig out how to run this pw201. the instruc. r a little hard to get. is their an easy way to explain how to thread and bobbin thread this machine
Electronic sewing machines have a sensor that knows when you are winding. Just place the bobbin on the spindle and push it over until it locks for bobbin rewind. Place thread through one of the holes and allow the bobbin to turn. Now step on the gas and let it fill up.
Take your bobbin carrier out. Place bobbin in carrier so the thread is unwinding, counter clockwise usually. Place the thread under the little slit and pull it until it feels like it is under a pressure. To check for this pressure (tension) hold the thread carrier with thread under tension and gently bob. It should allow a small amount of thread to extend. If not then loosen the screw. If too much extends then tighten. Now, place the carrier and bobbin in the sewing machine and make sure the snap is heard when you place it in there. It has to be seated. I believe this is a electronic machine and you won\'t have anymore problems because it will do the rest of your needed things before you sew. HOPE IT HELPS
Apr 26, 2014 | Sewing Machines
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Sewing machine needle won't go down to catch bobbin thread
make sure the bobbin is inserted correctly
also make sure the thread has not come off the thread take up lever
if none of these suggestions help, then you should consider
taking the machine to have it service, to see if it's out of time
Jul 31, 2012 | Brother Sewing Machines
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
try rethreading the machine top & bobbin
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
The sool is making a crunching noise and is sticking and won`t sew
If you mean spool, then it may be inserted wrongly or there may be broken threads stuck in the raceway causing it to jam. The thread should also be running clockwise in the bobbin
Dec 18, 2010 | Janome 659 Mechanical Sewing Machine
Brother LX3125 Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
