Question about Music
Sticky piano key - Music
  • Music Master
  • 5,603 Answers
If the keys feel sticky, clean gently with soft cloth wetted with Windex. If you mean the keys stick down we have no idea of what brand or type of piano you have and there is no way we can help you without more information.
Posted on Apr 11, 2011
3 Suggested Answers
marinelvr18
  • 5 Answers
SOURCE: Sticky Keys for Yamaha Digital Piano YDP-121
have you tried using the can of air. you can get it at almost any drug store walmart or kmart. just spray the can of air between the keys and they should become unstuck.
Posted on Dec 13, 2008
  • 5603 Answers
SOURCE: My Yamaha YDP-121 digital piano has a key that is
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Posted on Nov 29, 2009
Testimonial: "sounds good but i am a novice with repairs and do not really understand all the terms used. also, i am not sure how to go about fixing or getting repl"
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
How can I repair a lifted key?
If it's an ivory piano key just clean it a bit underneath with sand paper then glue it down with aquadhere and sticky tape until set.
Mar 29, 2016 | Music
We bought this upright piano for our daughter to learn on but I can't seem to find any info on it. Serial number 23930. Any info would be fabulous. Thank you.
Remove the front of the piano. Remove the middle C key complete from it mounting pin. You may find the production date and its full service history written in pencil on the side of that key. A piano tuner told me this after I told him that I had removed all the keys to clean them and I was surprised to see the whole history. It said it was standard practice.
Here is some other information.
Concord Mission Style Upright Piano ' The Antique Piano ...
antiquepianoshop.com/product/192/concord-mission-style-upright-piano/ The Concord Piano Company was controlled and manufactured by the famous George P. Bent Piano Company of Chicago, and they built pianos for several ...
Concord ' The Antique Piano Shop
antiquepianoshop.com/online-museum/concord/ (SEE ALSO: CROWN, GEORGE P. BENT) The Concord Piano Company was ... and manufactured by the famous George P. Bent Piano Company of Chicago.
Upright Piano Value ' key-notes
www.key-notes.com/upright-piano-value.html Jun 16, 2014 - Question: I have a Concord upright cabinet grand piano, serial ... Albert's reply: Piano values are based on information such as manufacturer, ...
Piano Manufacturers in Illinois between 1842 and 1908
https://sweeneypiano.com/.../manufacturers/il_piano_manufacturers.cfm The names of Piano Manufacturers and the date year the company was established in the state of Illinois between 1789 and 1911. ... Company, Chicago. Foley & Williams Piano Manfacturing Company, Chicago ... Concord Company, Chicago.
Jan 19, 2016 | Music
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
How to unStick Keys onYamaha YDP121 Piano
use wd 40 and a soft clothe apply on the sticky areas give it time and clean after .
Jun 28, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
Names of piano's that have more than 88 keys
If you have cubic dollars to spend "B?sendorfer" makes a 92 and 97 key piano... These are NOT electronic but are stage Grand Pianos.
Jan 10, 2011 | Yamaha NP 30 76 Key Lightweight Digital...
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I need to repair a sticky key on a P120. Is there a repair manual?
Call around to local music stores and ask about the closest authorized Yamaha repair center. If it is still under warranty, they should replace the keybed free of charge.
Here is a great website with the do's and don'ts about self keyboard repair. http://www.mikebarden.com/view.php/area/1/digital-piano-repairs-keyboard-repairs
Sep 17, 2009 | Yamaha Full-Size Keyboard
Korg C-3500 Piano Sticky keys and lubricant
Hi. I saw this looking for info on the C3500 of which I own one myself. I don't know the answer to your question but I found a site where you may buy a downloadable c350 service manual for $45. Go here, http://www.musicparts.com/products.asp?Company=Korg.
Regards,
/Mats Rahm
Sweden.
Dec 11, 2008 | Korg Music
Dec 07, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
93 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
