Question about Sony KP-53V45 53" Rear Projection Television
Picture in Picture
A button was pressed and a PIP screen popped up and now i dont know how to get it off. I pressed every button on the remote. I can move the little screen around and i can make it big and small, but nothing seems to make it go away.
  • 1 more comment
  • danrv Aug 06, 2008
    the tv is a sony KP-53V45
  • thegrants282 Feb 06, 2009
    The PIP button was pressed by accident and now we can't get it to go off. We can move it around and make it bigger and smaller but can't get it to go away. There is not an off PIP button and it is the correct remote for the TV it came with it...
  • tedrocker Apr 19, 2009
    I have the sqame prolem - The PIP button was pressed by accident and now we can't get it to go
    it to go away. There is not an off PIP button, The remote for the TV it came with it..Is there any way to turn off PIP without an original remote?.
I have the same TV. My remote control has a PIP OFF. If you don't then you have the wrong remote control.
Posted on Sep 09, 2008
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
I HAVE A BLACK SUZRE BOX SHOWING AT THE BOTTOM OF MY SCREEN. SOMEONE TOLD ME THAT IT WAS THE PICTURE IN PICTURE. HOW CAN I GET THIS BLACK SQUARE OFF OF MY SCREEN.
That's a text box not pip. Press the cc button repeatedly on your remote control or go into your menu and find the closed captioning setting. There may not be a menu item for closed captioning. It might be a button on the remote only. You should be able to scroll through the closed captioning options when pressing the cc button to choose off. You are more likely in the text1 or text2 mode right now. If I am wrong and it is pip there should be a pip button that will enable you to turn this feature off (or a menu option). If you need the remote that originally came with this television try http://www.replacementremotes.com/
Jul 22, 2011 | Televison & Video
I have the 2000 Sony Trinitron model KV 27FS16 tv the picture in picture popped up on the screen cant get rid of it. I don't have the original remote anymore. Please Advise
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
May 08, 2011 | Sony KV-27FS16 27" TV
I cannot get the picture-in-picture off the screen
Hello
You must press function before you can control PIP with the yellow labelled buttons.
Press to change the TV channel in the window picture.
Press to move the location of the window picture [counterclokwise] around the main picture.
Press to freeze the window picture with Freeze button.
Press freeze button on the remote handset again to restore the previous screen.
Ok
Oct 26, 2010 | Sony KV-27V65 27" TV
I need to get the pip screen i think its called off of the regular picture on the tv how do i do that because i dont even know how it poped up since the remote broke and i have a universia remote that...
You will need to either find a Sony remote with the PIP off button or a Sony remote with a RESET button. Borrow from a neighbor if needed. The newer TVs do not have a reset button, but the old ones do. The PIP OFF is self-explanatory... The RESET button method requires you to do this: With the TV on, point the remote at the TV and press and hold the RESET button on the remote, then press the power button on the TV. The TV we do a factory reset.
Mar 15, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Open Questions:
Televison & Video Logo
176 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
