If your motherboard is ECS G31T-M7 v1.0, it may not be compatible with the Radeon R7 240 GPU that you purchased. You should check the manufacturer's website for the list of compatible GPUs and also check the specifications of your motherboard to see if it supports the GPU.
If your motherboard is indeed compatible, it is possible that the error message "flash part is not supported" is due to an outdated BIOS. In this case, you should try updating your BIOS to the latest version using the ECS Live Update Utility or the BIOS update utility provided by your motherboard manufacturer.
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
depends on the case that it is in. for the physical size. but normally any ATX power supply of 350watts or better is a good selection.
i need a picture of the case to be sure
