Question about Sony PlayStation® 3 (60 GB) Console
My ps3 turns on, but the screen just stays blank. All of the plugs are in correctly, but the screen just stays blank.
    Problem Solver:
  • 7 Answers
Turn your playstation off so the light is red, then hold the power button for 6-7 seconds til it beeps twice, and u should be good,
Posted on Apr 12, 2011
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the screen is black
Have You Pluged In The Yellow Video Cord All The Way?
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
THE PS3 SCREEN STAY BLACK EVEN WHEN THE CONSOLE IS ON
Hi, I can help you but i need you to turn everything on and at that blank black screen insert any Disc wait like 2 seconds and tell me if the top right hand corner if theres a small loading icon looks something like a water drop ripple that pops up. If so i had the same exact problem, they way i fix mine is I replaced my HDD (2.5 SATA drive) which is located on the left side of the ps3 when layed down horizontally if you didnt know already. I went ahead and bought a new 2.5 SATA drive and replaced it with my old one that was causing the problem, most likely is caused buy corrupted data files. HOpe this helps
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Blank screen
Hold the power button (5-10 SECS) when turning it on and your PS3 will automatically set the correct video output.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
How do i reset all my settings for my PS3? I've been using an HD cable for my video/audio output and when i switch to the regular cables the screen just stays blank and I can't get to the menu. How do i...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Aug 01, 2008 | Video Game Consoles & Games
Cant acess ps3 Xbar menu,still plays games
it sounds like you haven't set the display settings correctly. turn off your ps3 and try using the red,white,yellow cables (make sure everything is plugged in correctly). if you get a signal, then change the display settings to whatever connection you will use.
hope that helps
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
