Question about Miller Welding Tools
I have a Miller Shopmaster power source attached to a Miller model 22A wire welder. The problem is when the heat is set above 150 the wire feed pulsates and will not maintain a constant wire feed. Do you have any solutions?
    Problem Solver:
  • 7 Answers
Check to make sure wire feed brake is not set too tight and that all cables and gun are clean. Also check wire feed wheels are clean and in good shape
Posted on Apr 11, 2011
When I push the trigger I lose my voltage to run the feed motor, the motor works with other power source
Had the same problem with mine but mine isn't miller and don't know if your's is built the same but if you access the inside of the machine there's there's a large copper spool inside and that wire feed handle is powered through it. The connection heats up over time and becomes a short. I re spliced mine then soldered it and then cut piece of copper tubing and crimped it around the connection and soldered that as well.
Corrected the problem and I tried pretty much all listed solutions other then this first. Tried the new liner in the torch, the new tip and clamping the wire feed assembly with a clamp instead of the tensioner. All failed. I stumbled on to the fix accidentally when I was trying to install a more heavy duty fan. Hope this helps. Good luck.
Apr 21, 2016 | Miller Spoolmatic 30a Mig Spool Gun 130831
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
How much does this welder cost?
Hi:
That welder in new conditions should cost about 350.00 dollars. Used probably just 120.00.
Oct 17, 2011 | Firepower Flux Core Wire Feed Welder 88...
Miller mig welder #175 stopped welding, fan comes on and wire does feed, just no weld.
This usually happens when the main Power semiconductors fail. You need to check out the two main places, the Power Supply, make sure ALL voltages are correct, and the main Output semiconductors, check these to make sure they are Not open circuit or short circuit.
http://www.millerwelds.com/service/ownersmanuals.php
Above is your support link.
You need to contact Miller and obtain a service manual, before attempting to service this unit.
Aug 14, 2010 | Miller Welding Tools
Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Dec 28, 2009 | Miller Welding Tools
I have a Miller 130xp set up for .035 wire. I
It's called the fire feed wheel. They sometimes come in sets but, running .035, you probably have one grooved and one flat. Any welding supply that handles Miller welders should have them or be able to get them.
Sep 17, 2009 | Miller Welding Tools
Wire feed assembly for a Astro power mig welder 110
go here and buy the parts i have one too, fix it and sale it!!!!! (JUNK WIRE FEED )
http://store.daytonamig.com/wifeteas.html
Jul 11, 2009 | Miller matic 140 Mig Welding Package W/As...
I have a miller 180 autoset that does not feed the wire
If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Welding Tools Logo
126 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
