Question about Frigidaire FGX831F Top Load Stacked Washer / Dryer
Frigidaire FLXE52RB58...washer filled, but did not agitate. Noticed an electical odor and unplugged it-now it won't work at all. Suggestion?
  • 1,998 Answers
First thing this is the entire schematic for your machine http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLXE52RBS8/1428/0152000?searchedModel=FLXE52RB58&blt=11 so the dryer still works correct? first thing would be the lid switch to check on the washer if the washer is not working the lid switch i think is located at part number 50 on this diagram unfortunatley this diagram is a bit fuzzy so you will have to double check on this http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fY2705246-00005.png if you have any questions message me back you should be able to hear the lid switch click as you open and close the lid you can also take a electrical wire and strip both ends and then go to the connector that the lid switch plugs into and connect the electircal wire now that you have stripped both ends it becomes a jumper wire and connect between points 1,3 on the switch this bypasses the switch itself and can be used in this manor as a temporary repair until you replace the switch itself note that if you do open the lid after you have done this the unit will still spin and agitate not like before when it would stop be extra careful if you jump this switch around small children and if you have any further questions message me back and please also message me back with your finds if the lid switch checks out to be in proper working order then message me back this information as well this is where you would start troubleshooting your unit and is usually one of the first probelm areas with the machineThanks Rick
Posted on Apr 10, 2011
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Smelly clothes and washer
Washer smells foul...this is often a build up of soap, water, too many chemicals and this has left a residue, and the mildew moves right in and it stinks. This builds up is often on the inside of the outer tank.
Many times that this happens is when people use to much soap and then they only do laundry once a week.
One good solution to help your odor problem...it works well...in a top loader I recommend 2 cups of cascade and 2 cups of bleach, fill your machine with hot water and let it agitate. At the end of the agitation/wash cycle, let the machine sit and soak for about 10-15 minutes to work on your scum, then close the lid and let it complete. Next load run whites to be safe all bleach is out. This should help.
On some really bad odor problems, you may have to remove the inner basket to scrap off the build up from the inside of the outer tank. You may will need special tools to remove the inner basket.
Fabric softener is also nasty for building up inside and under the agitator.
It is recommended to use half to a quarter of the detergent that the package recommends.
Other things that may help, leave the washer lid open between laundry days. Never cover your washing machine with those plastic covers.
Nov 11, 2009 | Frigidaire ATF6000ES Front Load Washer
The frigidaire agitates but does not fill with water...and yes the water is on.
Hi, UNPLUG the washer and remove the panel behind the controls. Locate the water level switch (has 3 wires and a 5/16" hose). Remove the hose and then plug the washer in. Start the wash cycle and see if it fills. If it fills, you will need to unplug the other end of the hose that fits on a cup attached to the side of the tub.
Please let me know if this helps you so I can give you more instructions.
Thanks
Vic
Jul 11, 2009 | Frigidaire FWS833A Top Load Washer
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FGX831F Top Load Stacked Washer / Dryer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
