My kolin split type aircon is not cooling and its says F2 on control panel . What is the problem with my unit?
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
raulcvalenzu
  • 11 Answers
SOURCE: Kolin window type aircon shuts off by itself
a wiring connection in cotrol of on / off are malfunctioning
Posted on May 27, 2010
SOURCE: York mini split unit has power but will not come on stand-by.
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Posted on Feb 20, 2011
The indoor of carrier split type aircon is having a heating function, if they have , how can I set in the remote control
The Split system control is not working and you need to check thermostat wirings and the control on the splitter
Jan 12, 2015 | Carrier Heating & Cooling
Split type aircon us12a1ve
Same here. Your temperature difference is normal at 15d. Need to know your set-point. If the unit cycles on close to set-point, Then it's probably normal. Without more info your question doesn't make sense.
Jan 03, 2014 | Heating & Cooling
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Jan 06, 2010 | Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Jan 12, 2009 | Frigidaire FAA065M7A Air Conditioner
Heating & Cooling Logo
441 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
