Question about Bionaire BSF1731RC Stand (Pedestal) Fan
The fan motor works but it won't oscillate or even stay in one position it falls to one side. How do I fix this?
    Sergeant:
    Champion:
  • 247 Answers
Ossilate gear assembly damage need replacement
Posted on Apr 09, 2011
My lasko tower fan works bot stopped ossilating
Well could be several things that could make it not oscillate. Motor is bad, stripped out teeth or gear slipping on motor. You would have to take it apart and see if you are even getting power to the motor.
May 28, 2015 | Lasko Dryers
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
Fan will not oscillate anymore. it makes a clicking noise like it's stuck
follow this steps and fix it. God bless you
f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
Nov 14, 2013 | Tower Aloha Breeze Fan
Hi, I have an aloha 3 speed oscillating pedastal fan. motor is almost seized. can it be fixed?
What is the estimate rotation rpm at fastest speed ? Normally pedestral fan is a 6 poles or 4 poles single phase motor?
Jun 08, 2012 | Aloha Housewares Dryers
Noisy table fan - Vornado silver swan
the electric motor bearings and/or brushes have worn. soft metal screws is an indication of the quality of the motor.not good. sometimes units are of nice design, look and high price but they throw in a cheap chineese motor. all you can do is put a few drops of oil on the motor bearings, its ok to do when this worn out
Jul 30, 2009 | Vornado Silver Swan Table Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
My windchaser WCUFI wobbles so bad I think it's about to come off
Literally fixed this exact problem on mine today. I couldn't find instructions so I made some on snapguide. Search wcufi-tower-fan/
May 31, 2009 | Windchaser WCUFI WindColumnUltra Tower Fan
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
273 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
