Question about Garden
Toro GTS 20332 lawnmower won't start. It's guaranteed to start. Bought it last November. Just put new gas in it, checked the oil, went to pull it and it didn't even sound like it was trying to start..
  • 12,061 Answers
Hi, well, if it hasn't been started since November? then maybe, the spark plug has fouled, change, DO NOT clean and replace unless you have NO alternative. Also check, the spark plug lead. Replace if possible with a new one. Check all connections, to magneto/alternator, make sure you have voltage? Check the ignition circuit, the electronic ignition module too. Then Check to see if you indeed have a spark, hold the plug, against the case of the motor, and see if you can discern a spark, it should be big, and nice and blue.purple.
Also ensure gas is getting to the carburettor, take the fuel line Off at the carb, and see if gas is flowing?
I would imagine though you have sufficient gas.
If it uses a battery, then make sure this is OK too.
Below is your support link so you can obtain your manual to help repair. at the bottom customer support, and manual links are there.
http://www.toro.com/home/mowers/recycler/20332.html
Below is how to troubleshoot the motor...
http://www.ehow.com/how_6552737_toro-lawn-mower-engine-troubleshooting.html
below is how to repair small motors an easy how to...
http://www.repairfaq.org/sam/lmfaq.htm
Posted on Apr 10, 2011
Toro 20332 will not start ....new, only used twice
Check the shut of switches for blade , brake , deck, pto. You may have just shut down the tractor and forgot to disengage these safety features. Good Luck Friend.
Apr 21, 2018 | Toro Garden
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Toro 20332 pull cord won't recoil mower 2 Montserrat old
I lost my manual can I get a copy fax or e-mail I need to know type engine I have 20332 so
I can order a part
Jul 22, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
I have a Toro 20332 that stopped running after 20 minutes and would not restart. Tried several days later and it would start for a few seconds and stop again. Took it to the Tor dealer twice last year...
Just take off your carb and give it a good cleaning. Be careful and watch how everything comes apart so you can put it back together with little or no trouble.
Jun 07, 2010 | Toro Lawn Mower With Toro Power Tools
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
