Question about Broderbund The Print Shop Design Suite Professional Edition Full Version for PC
I purchased broderbund print shop 2.0 professional for windows 7. Every time I try to start a project I get 'program has stopped working' message and the application shuts down. Not sure what to do to fix it.
4 Suggested Answers
matt2414
  • 247 Answers
SOURCE: Is print shop version 21 compatable with win 7?
http://www.broderbund.com/store/broder/en_US/DisplayCategoryProductListPage/New_Releases/The_Print_Shopreg/parentCategoryID.13527700/categoryID.13528200
If even the earlier version isn't compatible,and my search only shows upto 2.0,then I would assume that 2.1 isn't ready either.
Posted on Mar 23, 2010
Testimonial: "Thank you! It doesn't make my wife happy but at least now she knows!!"
SOURCE: Purchased Broderbund Print Shop 23.1 Deluxe. Two
Yes, otherwise you have to manually insert the Art disc every time you want to use the Art & Photos.
Posted on Oct 12, 2010
mariolands
  • 2296 Answers
SOURCE: Windows 7 Professional + compatibility with
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Broderbund Print Master Platinum Version 18, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Posted on Nov 25, 2010
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
New computer has Windows 7. What version works on Windows 7?
Older programs can usually be run in Windows 7 using compatibility mode.
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Mar 04, 2011 | Broderbund PrintShop Signature Greetings...
Windows 7 Professional + compatibility with Broderbund Print Master Platinum Version 18
Nov 20, 2010 | Broderbund PrintMaster Platinum Version 18
I can't open sig. files on window 7 keeps saying not supported will not allow me to use the software to open either. no matter that i the print shop as default
Print Shop 20 is not completely compatible with Windows 7. For example, when I try to open a Print Shop 20 project on my Windows 7 computer, by double-clicking on the file which is displaying the Broderbund logo, I receive an error message which says, "There was a problem sending the command to the program." And, even though the Print Shop 20 file will eventually open, it actually opens in PrintMaster.
It is, however, possible to force the file to open in Print Shop 20 by doing this:
1. Open Windows Explorer, then find and right click on a Print Shop 20 *.sig file.
2. When the menu drops down, click on 'Open with...'.
3. When the 'Open with' window opens, make sure that there is a check mark in the box next to 'Always use the selected program to open this kind of file'.
4. If Print Shop 20 is displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on Print Shop 20, then click on OK.
If Print Shop 20 is NOT displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on the 'Browse' button.
5. When the second 'Open With' window opens, navigate to this folder
C:\Program Files (x86)\The Print Shop 20\The Print Shop 20
then, click on the tps.exe file.
6. Then, click on 'Open' then click on 'OK'.
This should cause all *.sig files to automatically open in Print Shop 20 when you double-click on them. However, since file associations are always based on the file extension of the project file, it might be necessary to repeat the process above for all Print Shop 20 file extensions.
Hope this helps....
Nov 17, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I own Broderbund's Print Shop Deluxe Version 20 and recently had to purchase a new computer. It came pre-loaded with Windows 7, and now Windows says it will not touch my stinky old version of The...
U can check to see if there is a Broderbund patch to enable it to work in the win 7 environment. If not available, you are screwed.
Who needs seven ?- go back to XP and enjoy your program to the fullest.
Jun 20, 2017 | Broderbund The Print Shop 20 Deluxe for PC
Does not read .sig files
Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; in work-related e-mails, the signature may also include the name of the person's company, the person's title, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook
tri.gif Microsoft Outlook Express
Broderbund Sign File Popularity 3.gif Average Category Image Files File Description Image format used for signs and posters created with Broderbund graphics software, such as PrintMaster and The Print Shop; can be opened with the program that created the file and possibly with other Broderbund programs or versions, but compatibility is not guaranteed. Program(s) that open sig files mac.gif Mac OS tri.gif Broderbund The Print Shop
windows.gif Windows tri.gif Broderbund The Print Shop or PrintMaster
Jul 02, 2009 | Broderbund The Print Shop 20 Deluxe for PC
Broderbund The Print Shop Design Suite Professional Edition Full Version for PC  Logo
112 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
