Question about TP-LINK TL-WR541G Router
Cant find my pin code on TR-WR541G - TP-LINK TL-WR541G Router
2006 V6. Where is TR sensor located?
the absolute first ting to do when a car will not start is to have the fault codes read to find the fault area
what is to say that after you find the TR sensor and waste money replacing it that the fault is a broken timing belt
Nov 30, 2015 | Pontiac Grand Prix Cars & Trucks
TP-LINK TL-WR541G Router how to change the language Chinese to english
  1. Make sure you know your hardware version!
  2. Download firmware update in English from TP Link website and unzip.
  3. Connect computer to router with Ethernet cable as per manual and in your web browser window enter http://tplinklogin.net then enter user name and password (admin,admin) to access the router Configuration Utility.
  4. From the English manual note the location in the configuration utility menus of the firmware upgrade utility. I.E. Go "system tools" (last entry in menu) then "firmware upgrade" (3rd item down). I know it's written in Chinese but you can count right?
  5. Select your unzipped file location in the window and press the button beneath.
May 10, 2014 | TP-LINK TL-WR541G Router
Error while upgrading firmware
You can try to find the old version of firmware and see if you can load it. If that fails the router is garbage.
Mar 30, 2014 | TP-LINK TL-WR541G Wireless Router
Location of transmission range sensor on 1996 oldsmobile cutlass ciera sl
code p0705 refers to transmission range (TR) sensor /switch, PRNDL input-circuit malfunction===causes ---wiring---TR sensor/ switch---ECM ---TCM
Have the switch checked put and the TCM ( most probable)
Feb 23, 2014 | 1996 Oldsmobile Cutlass Ciera SL
Cant find simpel answer code po708
Trouble Code: P0708
Transmission Range Switch Circuit Malfunction (Shorted)
Possible Causes:
TR sensor signal circuit is shorted to ground.TR sensor is damaged or has failed..TCM has failed.TSB 01-40-020 (7/01) contains information about this code.Here is what is listed for this code.
Dec 29, 2012 | Hyundai Cars & Trucks
TL-WR541G : i can't log to router and also do reset for it
Push and hold the reset button for 30 seconds or so, it's usually in the back of the device near the power AC jack. http://www.tp-link.com/en/support/download/?model=TL-WR541G&version=V7
Nov 28, 2012 | TP-LINK TL-WR541G Wireless Router
Po705 2001 mustang auto
CODE PO705 IS DTR SENSOR TR SENSOR CIRCUIT MALFUNCTION. POSSIBLE CAUSES, DTR OR TR SENSOR CONNECTOR IS DAMAGED OR SHORTED, DTR OR TR SENSOR SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND, DTR OR TR SENSOR SIGNAL CIRCUIT IS SHORTED TO VREF 5V, DTR OR TR SENSOR DAMAGED, PCM HAS FAILED.
Jun 24, 2011 | 2001 Ford Mustang
I have timer tr 611 top teben there is a pin code lock and me forgot the code some one know master cod
There is no master code - you have to send the unit back to the suppliers : Phone Timegauard on 0208 4508944.
Sep 19, 2010 | Heating & Cooling
Check engine light is on. Is it the PO705 vehicle speed sensor A maken it do that?
Yup, if you scanned your engine computer and you got a code P0705, you can bet that's why your Check Engine light is on.
P0705, however, is NOT a Vehicle Speed Sensor code on this vehicle. It is a Digital Transmission Range Sensor code. It is caused by an open or shorted circuit in the TR-1, TR-2, TR-3a or TR-4 circuits. This code CANNOT be set by an incorrectly adjusted TR Sensor.
Oct 18, 2009 | 2000 Ford Crown Victoria
TP-LINK TL-WR541G Router Logo
224 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
