Question about Refrigerators
Fridge side not cooling i have unplug for a minute and plugged back in starts fine and then i hear a click sounds like compressior is running but not getting cold
  • btscreamin Apr 09, 2011
    its a frigidare gls66 side by side and yes i hear a fan blowing there is also alot of condensation on fridge side
  • btscreamin Apr 10, 2011
    also the freezer is staying cold
  • Refrigerators Master
  • 2,180 Answers
First off what is the brand name and model number?is the freezer cold?if so when you open the freezer door do you hear the fan blowing?all a fridge does is get cold in the freezer and the evap fan blows cold air from the freezer to the fridge side that's it,if you don't hear the fan when you open the freezer you have a bad evap fan motor,but send more info.
Posted on Apr 09, 2011
  • 5 more comments
  • Sal DeAngelo Apr 10, 2011
    that's not the model number,open the fridge door,up on the right hand side near the cieling you should see a tag with the model number or if it's an older machine the number could be down at the bottom hindge on the fridge door,and remove the kickplate to see it.also is the fridge running warm or what's happening to it and how old is it.the more i know the better i can help you.one more thing,open the freezer door,from the bottom up remove the second draw or bin and put your hand on the back wall,is the ice or frost on the back wall?
    ok its a JSI 26 its 2 yrs old the freezer seems to be running fine its minus 6
    there is a lil frost not much though. it seems there is very little cold air comming to fridge side
    i'm sorry but the model number isn't coming up.all a fridge does is the freezer gets cold and an evap fan motor blows cold air from the freezer to the fridge.you siad the fan was blowing in the freezer when you opened the door,i want you to put your hand in the fridge section up top where the cold air blows in,do you feel the air coming in,if not you could have a damper in it and the damper door isn't opening to let the air come in,when the fridge side gets cold enough then the damper door closes,i need the model number to look up your machine to see if there is a damper in there,when you looked at the number did it say model number next to it,also you'll see a serial number there to but i just need the model number,
    one more thing if you unplug the machine you have to wait 5 minutes before you plug it back so the compressor can reset
    the model # is GLHS66EJWO that is the only one i see... there is very little air coming through the back of the fridge.... it is cooling but, it is taking its time.
    that's the correct model number and there is a damper in there part number 241600905 and it's around 60 dollars.when you turn the control to make the fridge colder or warmer the damper door will open wider or close more to adjust to how much cold air enters the fridge from the freezer,if you look at the back left side you'll see the damper door,in your case it's closed not letting cold air in this is the part you need to change.order the part,there should be derctions in it,and change out the damper,should take you around an hour to do,you can unplug the machine when you change it.from what you told me this sounds like your problem.good luck.
    thank you for your time and patience
Not freezing or cooling and compressor clicking on and off
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Mar 29, 2014 | Maytag MZD2766GES Side by Side...
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
4. Wait one hour.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
My fridge is not working
4. Wait one hour.
Try this and let me know.
have a good day
Feb 23, 2011 | Refrigerators
MSD2454GRW. Clicking noise for about 10 seconds then shuts off. Freezer is thawing. Fridge "appears" to be cooling fine...not sure. Help...don't have the $$ to hire someone.
4. Wait one hour.
try this and let me know if it helps.
Feb 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
4. Wait one hour.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
4. Wait one hour.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
