Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I was cleaning my Poulan Pro 262 chainsaw, and accidentally caused the chain brake from working correctly. The brake will not stop the chain when pressed forward. The brake is not tight enough around the clutch drum. Can anyone help?
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
  • 211 Answers
SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Posted on Dec 02, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Pro Chainsaw chain tensioner is junk
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
Testimonial: "Thanks -- that's exactly what I was hoping to find. It's wonderful to be able to tap into expertise like this. Very Happy!"
My Poulan Pro PP5020AV chainsaw brake is engaged & will not disengage. The chain continues to rotate. Any suggestions on how to fix?
If the chain continues to rotate than the chain brake IS Disengaged. When the chain brake is Engaged, the chain is locked. Any problems with the inbuilt safety features needs fixing by a Poulan engineer.
Sep 29, 2016 | Poulan Garden
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Chain brake on my poulan pro 50cc does not lock-in place. It just swings freely from side to side.
a worn clutch shoe or brake band is the most common cause, remove the side cover and actuate the brake, if you can wiggle the shoe or turn it at all then its for sure the shoe or band
Jan 23, 2014 | Poulan Pro 20-inch 2-cycle 50cc Gas...
After installing the chain on the new poulan chainsaw, the sprocket gear will not turn, I made sure the cover nuts were loose upon tightening the chain but the sprocket gear will not turn with chain on,...
Did you make sure the brake was off before re fitting the side cover, if not the band will be smaller that the drum and will jam the drum and stop it from turning.
Aug 12, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ineed the proper mix for gas. for a Poulan pro 262 18in. chain saw.
Hi sephil99125...
50:1 oil to gas ratio
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 09, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain drive gear is locked up, will not turn. Saw was purchased March 28, 2010 at Wal-mart in Bedford,IN. Hasbeen used very little.
Just want to make sure you haven't overlooked the obvious: Is the chain brake accidentally engaged (Handle on top should be in the forward positon--if not, give it a quick snap forward to disengage the chain brake). Good luck.
Oct 21, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulin Pro 46cc he problem I'm having is with the brake. How can I adjust it to stop the chain.
The likely problem is that the 'toggle' mechanism for the brake is plugged with dirt/sawdust and won't allow full travel of the brake. Try compressed air to clean it out. The brake band could also have excessive oil on it--wipe it clean along with the clutch outer drum surface. Hope this helps!
Sep 06, 2010 | Poulan Pro Chain Saw 46cc 20"
I can't get the cover back on after I fixed the tension on the chain. There is a metal ring and it no longer seems to fit.
take your time with this step! The steel band is part of the brake for the saw. You will need to take very special care and take your time when putting it back together.
The trick is in the braking lever. you will need to pull back on the braking lever, align the steel band over the steel drum, and and align the two contact points that will connect the steel band to the braking lever. After it is in place actuate the lever to see if it is working correctly. This function should cause the chain to stop moving and move when the brake is released. Where strong rawhide gloves to protect yourself from the chain. Good-luck.
Jun 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
87 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
