Question about Peg Perego John Deere Gator HPX Ride on Toy
I'm looking for a right front fender, and two rear fenders for a 2004 6x4 gator, preferrably used
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 12, 2012
Fender serial number look up for fender stratocaster SN: E986120
What kind of vehicle is the fender on, and which fender, such as left front, right front, left rear and right rear? Will you do the work, or a body shop? What about paint matching, which is an art in itself?
Apr 24, 2017 | Fender Music
What is all involved when removing the right front fender of a 2002 Ford Taurus?
no -- the bolts holding the fender on are along the inside under the bonnet in the gutter , up under the fender at the rear and around the front panel
you will have to remove the plastic inner guard to get to some bolts
Jun 30, 2015 | 2002 Ford Taurus
How do i remove the rear fender on 2012 nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THEN you can remove the seat post with its washer and screw.
Jul 04, 2014 | 2011 Harley Davidson XL 1200N Nightster
How do i remove rear fender on nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THENyou can remove the seat post with its washer and screw.
How do i remove rear fender on night rod special
To remove a 2011 VRSCDX rear fender FIRST remove the main fuse under the right side cover first, then remove the tail light open the seat, remove the seat pillion, remove the fasteners and the passenger pillion, remove the electrical caddy and the six fasteners and the washers from the fender, remove the fender from the inner fender by lifting upward and sliding the fender back, remove the inner fender by removing the rear shocks and fasteners.
To install a 2011 VRSCDX rear fender FIRST install the inner fender and fasteners, tighten the fasteners to 95-110 Nm (75-81 ft-lbs), install the rear shocks using shock mount fasteners and tighten the fasteners to 41-68 Nm (31-50 ft-lbs), install the rear fender by sliding it into the slot on the tail lamp panel and aligning the fender with the bolt holes on the inner fender, install the six fender fasteners and tighten them to 4.5-7.5Nm (40-66 in-lbs), install the tail lamp, install the passenger pillion and its fasteners. And tighten them to 20-26 Nm (15-19 ft-lbs), install the main fuse, install the right side cover and ensure that the headlamp, tail lights and stop lamp and turn signals are operating properly.
Jun 04, 2014 | 2011 Harley Davidson VRSCDX Night Rod...
Rear fender
Hi Kirk, start with small increments of tightning in the front one side then the other then the rear same thing then back to the front untill you reach a torque value of 15 to 20 ft lbs. Good luck.
Aug 11, 2013 | Harley Davidson Motorcycles
Step by step proceedure to remove rear fender from 2000 fxdwg
1. Follow the taillight and rear turn signal wire harness to the 8-pin connector under the seat. Separate the connector. Remove the seven wires and the attached socket terminals from the connector.
2. Cut the cable strap from around the harness in front of grommet in the fender. Pull harness thru grommet in fender.
3. Remove (from underside front of fender) screw and washer from speednut on frame.
4. Remove turn signal lamps.
5. Remove screws and washers from rear of fender supports.
6. Remove license plate bracket.
7. Remove screws and washers from front of fender supports.
Nov 26, 2010 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
No side lights or rear lights
You have a caroded or broken connection on the right inner fender skirt. Check your connection plug also for corrosion. The power goes out of the fuse block on the left fender across the front to right fender then to the rear taillights.
Dec 29, 2008 | 1998 Lincoln Town Car
Front fender removal
Hiya... here's the details of fender removal/installation:
the left-side (same for right-side) fender has 6 bolts attached to the "sidebody" frame.
The bolt location:
3 are on the top fender-easy to find when hood is open,
1 is hidden at the rear of top inner fender-just open the left-front door wide to find it (early equinoxes had foam-like noise absorber material in it, just remove it from underneath fender after the wheelwell liner is removed),
1 bolt is hidden at bottom of front fender area at headlight/bumper area-you need to remove plastic wheelwell liner to gain access,
1 bolt is hidden at bottom of rear fender area where the black plastic rocker panel meets below the fender...
THIS area is probably the most difficult task to do since it requires you to remove a small bolt found on the front of rocker panel behind the front-left wheel then use a flat screwdriver or clip removal tool to pry open the black plastic **clip's 'dime-sized' head prior to pull out the clip's body (it has 8 clips underneath the chassis) then use your hands to grasp the rocker panel underneath, pull it down-toward you...this should do it....USE CARE during rocker panel and clip removal/installation so you don't break the clips!
It also has yellow plastic clips inside the rocker panel (used as a guide during installation into rocker sill holes-use caution not to break it)
**note: early equinoxes had rocker panel clips that you can actually pull it out from the hole, while later equinoxes has 'built-in' clips inside rocker panels that you don't see the clip heads below it due to engineering part design change**
Be sure to exercise care when handing this task!
Nov 20, 2008 | 2005 Chevrolet Equinox
Peg Perego John Deere Gator HPX Ride on Toy Logo
70 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
