Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor keeps going asleep and want wake back up
  • 11,361 Answers
It does the same when used it with another PC? If it is monitor, then it can be due to bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Posted on Apr 10, 2011
The WiFi keeps turning itself on. I turn it off and it turns itself back on ..
Why would you turn it off unless you are using another wifi adapter?
Most computers are set up to start the wifi when restarting the computer as default. If you don't want it on, don't restart the computer. I never restart mine, I just put it to sleep. It is dormant until you click something to make it wake. Nothing is working while asleep or hyberated. Perfectly safe, (but turn off the mouse it may wake with vibration of walking across the room).
Oct 25, 2014 | Computers & Internet
Monitor has power to it and signal from computer but is asleep and wont wake back up
Is it showing any flashing indicator lights?If not:
....You have to try a different vga cable if it is not built into the monitor, and make sure the pc will drive a known working monitor ok from the same port. If the pc is ok and there are no fault lights showing I would suspect the vga cable
Jan 25, 2011 | Computers & Internet
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
Same as the guy above me
You have a power supply in the monitor that powers the fluorescent tubes. That circuit board can be ordered on eBay for your model and replaced. Helpz, yes?
Jul 05, 2009 | Hannstar I-Inc TW-191D Monitor
Blank screen
please go to www.ge.com request manual
Jan 27, 2009 | GE 74801 Clock Radio
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
My HP1906 Monitor is asleep ... How do I wake it up.
Hi...there,
Well, new could be defective too... You're probably got a busted backlight inverter problems... Send it back for repaired. Happy Holidays!
Dec 18, 2008 | Computers & Internet
HP Vs17 17" LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
