Question about Garden
Have a Char-Broil model 4643222 Garden Chef Premium (circa 2002). Need a replacement 15" burner assemble & spark ignition push button/electrode assembly. Have found Char-Broil parts Nos. on web site for these parts but need confirmation they will fit my model. Burner - p/n 2384264 Spark kit - 4884681 Are parts still available for this model in the UK. If so who from. Regards Chris Oliver
  • 3,740 Answers
Hi Chris and welcome to FixYa, I am Kelly.
Here are the 2 sources in the UK I could locate:
Char-Broil International
Berrington Lodge
93 Tettenhall Road
Wolverhampton
WV3 9PE
tel: 01902 310136
fax: 01902 424524
email: prparker@globalnet.co.uk
CHARBROIL (UK)
C/O JACKSONS YARD
S81 7AU WORKSOP, OXFORDSHIRE (no link)
Phone: 01909 470746
GEO: 53.315356, -1.134370
After my search I totally understand why you came to FixYa. The 2 sites above are the only ones I could locate and one of them is questionable. Neither have an on line website.
Thanks for choosing FixYa,
Kelly
Posted on Apr 09, 2011
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
Where do you hook up the side burner igniter wire for model 463722712
Its a push fit tab that goes on to the electrode on the burner or off the spark generator on the gas control or its by its self
Aug 04, 2012 | Char-Broil CharBroil 4637318 Grill
Purchased model 463621611 and lost the assembly instruction manual. please email new one.
Here are 2 links (Part A & part B) of Owner's Assembly Manual you need. You can download and print then for future reference.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/4293a_110502_0.pdf
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/4293b_110502_0.pdf
Hope this helps you. Happy Grilling and thanks for choosing FixYa.
Sep 17, 2011 | Char-Broil CharBroil 4637318 Grill
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need a Burner Kit for a Char-broil 9000 DLX (Precision Burner)
You can order the burner directly from Char-Broil, if you have the correct Model Number. Go to
May 08, 2011 | Char-Broil Grilling
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
I'm trying to replace the paddle burners on this grill, but I don't know how to get the old ones off. Char-Broil said I have to disassemble the entire firebox to replace them. Is this correct, or is...
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find an exploded view with all the parts numbers at: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001103_463453305_a.pdf
If this was helpful, please vote yes. Thank You!!
Oct 04, 2010 | Char-Broil Advantage 463453306
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
Garden Logo
447 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
