Question about Electrolux Epic 6500 Vacuum
Carpet beater not turning on, rest of vacuum ok, reset button down
  • 694 Answers
Is the PN motor not working, or just the brush not spinning. If it's the brush, a new belt is needed.
If the motor isn't working, it could be due to several things. Follow the trouble shooting steps below.
1. Check all connections from hose handle to PN for discoloration. Any parts showing discoloration or melted plastic need to be replaced.
2. Attach PN directly to the hose. If the motor works, there's a problem in the wand wiring/connections.
3. Attach the Sidekick directly to the hose. If it works, but the full sized PN doesn't, there's a problem in the PN. Problems could include: wiring, connections, bad motor, bad switch.
4. If neither Sidekick nor PN work, the problem is likely in the hose. Potential problems include: bad wiring, connections, or bad switch.
5. You can try another hose known to be good to test the PN. If it still doesn't work, the problem could be in the canister itself.
I strongly recommend taking it to an authorized Aerus Electrolux store for diagnosis and repair if needed.
http://www.aerushome.com/storelocator/
Posted on Apr 11, 2011
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore model 401.39035900 vacuum cleaner beater problems
probably need a new motor and beater bar.
Feb 20, 2013 | Vacuums
Why won't brushes move on Commercial Carpet Pro Vacuum Cleaner
Luvumuch48tj:
Unplug the vacuum and lay it upside down on some newspaper. Remove the sole plate (bottom plate) with a screwdriver. Pull straight up on the brushes (called a beater bar) and remove the beater bar and belt. Remove the end caps and bearings from the ends of the beater bar (it may take a 2-grunt pull, or CAREFULLY pry the end caps and bearings from the beater bar with a screwdriver) Don't stab your hand with the screwdriver... That HURTS! Once you have the bearings and end caps off, remove the hair, carpet fibers and other gunk from the ends of the beater bar, end caps and bearings. Dribble a little rubbing alcohol on the bearings in the end caps and spin the bearings to clean them... keep dribbling alcohol in the bearings until the alcohol draining from the bearings is clear. Dry the bearings until there is no alcohol in them. Now would be a good time to check the opening in the vacuum head and the hose going into the body of the vacuum for clogs. Reinstall the bearings and end caps on the beater bar and reinstall the beater bar with a new belt in the machine. Reinstall the sole plate. Your machine should run like new.
Feb 15, 2013 | Carpet Pro CPU-2T Commercial Upright...
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
My dyson dc17 amimal's main turbine head is not working, is there a reset button or any other solution? I don't think it is the belt!
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
May 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc17 will not roll across the carpet, because their is too much suction.?
Turn on the beater bar with the gray button next to the red power button. The powered beater bar will "propel" the vacuum across the carpet.
May 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
Aug 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
145 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
