Question about Insignia 2.1 Speaker System (3-Piece)
I cant get sound and I am trying really hard to get it fixed I need help...quick.
  • Insignia Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 09, 2011
Help Black screen fan but no hdd light
No display and not booting after getting very hot is likely to be a GPU issue. This is repairable.
Jun 02, 2014 | HP Pavilion g7-1310us 17.3" Laptop
Cant get WEP save
Try doing a hard reset, if that doesn't work, try contacting the brand company and asking for a new one, or a quick fix.
Oct 04, 2012 | Craig CMP741d Tablet
Just replaced inner tie rod and now when start driving it ma;es an ugly sound and pulls hard to right where i got it replaced. Only going 20 mph .cant drive it... Jeep compass 2007. could itbe that it...
the inner tierod may have been put on wrong, but after any steering system parts have been replaced or fixed. it is a good idea to get it relined this is why it pulls so hard. wheels are not in alignment with each other. get it aligned, and all should be ok. if you leave it. it will wear tire down to nothing, really quick. good-dayt !
Feb 19, 2012 | 2007 Jeep Compass Limited
A whirring sound , then it went dead as if nothing is happening inside there,the PC do not recognige the HDD.
maxtor hard drives are really really unreliable one way to get it going is to hit it on a hard surface,the disc inside sticks and hitting it gets it going again.
this is only a quick fix i would suggest that you transfer the data on maxtor hard drive onto another drive
John
Feb 23, 2011 | Maxtor Hard Drive
How do i turn of my circulation fan in my bmw
Pop the switches out and disconnect them from the back. just quick fix but you will need to get it checked out. could just be a dodgy switch or maybe it needs freeing up, you can use wd40 on the electric switches and leave then to dry, does not cause any damage and drys very quickly.
Jan 20, 2010 | 2001 BMW 325
My portable harddisk snt working anymore after it fell hard
Sounds like it's hooped. Only way to recover data is to try to take it to a data recovery lab.... which can be pricey.
Sep 26, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Cant acees files on maxtor basics
try to use it via usb to SATA converter then u will see if it really work or not , if not try to use the same usb to SATA converter on another computer if doesn't work then ur harddisk controller is broken and u need to give it to its company to recover ur data
Jun 06, 2009 | Maxtor Hard Drive
HELP! My ps2 cant detect hard drive!
DGR8njct, Get a USB 2.0 to SATA/IDE/2.5/3.5 Hard Drive Adapter Cable . This will allow you to access the Hard Drive from a computer USB port. It doesn't sound good for you. If you do not want to get an adapter like I suggest, you can install the hard drive in a computer as a slave drive, and see if you can access the data. www.playstationclinic.com
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Insignia 2.1 Speaker System (3-Piece) Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
