Question about McCulloch Garden
Just got an older McCulloch chainsaw 00 600013u, I changed the plug and put new oil and gas in it. I got it to start with a lot of work and it ran great. I turned it off and cant get it to start again any sugustions
SOURCE: McCulloch pro/mac 10-10 chainsaw owners manual & gas to oil ratio?
I have the same problem.
Also I took it apart to clean and not sure if the electronic ignition is set correctly now.
Posted on Oct 13, 2008
Tinkertown
  • 16 Answers
SOURCE: wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Posted on Feb 16, 2009
revskank
  • 203 Answers
SOURCE: McCulloch chain saw pro Mac 10-10
if you are using McCulloch oil 40:1
Posted on Mar 02, 2009
  • 63 Answers
SOURCE: gas to oil ratio for a McCulloch power mac 310
When in doubt 40:1 is the always safe mix for any 2 stroke, synthetic oils 50+:1 use there recommendations. Always use the same(premium quality) 2 stroke oil to avoid fuel issues.
Posted on Mar 18, 2009
landsend
  • 1066 Answers
SOURCE: what kind of oil to use
any motor oil.
Posted on Apr 11, 2009
I have a McCulloch I385L trimmer that wont stay running
Try changing the gas to oil mix. You have too much oil in gas. Put more gas in to oil ratio. 25:1 should work. 25 parts oil to 1 liter of gas.
50:1, 50 parts oil to 1 gallon of gas. 4 liters to 1 gallon.
Jun 03, 2013 | Garden
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
When trying to pull start my Mcculloch chainsaw 338, its all jerky. ok last season. Help please.
Take the spark plug out and pull the cord to see if it stuck.
Drain all gas and get a new mix.Put back the sp and start.
If thr cord was unable to pull,thr pisto and crankshaft must be service.
Oct 26, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain saw has been sitting at dads old house . hasnt been run in 20 yrs. mcculloch (mac120). no oil in it or gas or spark plug. how should i go about getting it to run ?? i know put fuel in it . but size...
Don't think you mean electric..Anyhow when adding gas for the first time start after 20years, add a pint of oil to gallon of gas. If it turns over and starts, then you can lean it down later. Google for spark plug or go to manufacturers site. good luck
Sep 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have a McCulloch Bearcat. It sat all summer. I
Did you remove the old fuel?
Did you refuel it with a fresh oil/gas mix? Mixed to the oil suppliers recommended ratio.
The fuel that sat all summer probably contains ethanol. Ethanol draws moisture, moisture and the oil suspended in the fuel don't mix. The old fuel can be used in a 4 cycle engine. Try refueling with a fresh mix if that doesn't work we need to investigate further.
Lou
Sep 05, 2009 | McCulloch Garden
McCulloch Chain Saw Mod.600133C, need to know the proportion of
oil, gas ratio is 40 to 1 A plug for small gas engines will work
May 08, 2009 | McCulloch Garden
Trying to get McCulloch MS354 35cc chainsaw started
Stiff usually means good compression. So, pump the fuel bulb, put your foot on the flat in the handle, lock the throttle open using the button on top, set choke all the way out and pull. It should kick after a few pulls. Then close choke half way, and pull until it starts, then push choke all in. If it doesn't start, disconnect spark plug and take it out. Have someone watch while the sparkplug is held against metal engine to see if there is a good spark at the plug. If not maybe needs new coil. look at plug to see if it is wet, ie, gas is getting to it to isolate problem to carburetor.
Apr 27, 2009 | McCulloch Garden
I have an old McCULLOCH MAC 10-10 chainsaw that takes 40-1 gas. Take the metal air filter cover off, and look on the inside of it, it should tell you all the info you need like starting it, what kind of gas etc,etc
Oct 03, 2008 | Garden
Garden Logo
111 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
