Question about Bugaboo Cameleon Jogger
Can't seem to blow up the tyres on my bugaboo. Used the pump that's in the maintenance pack but no use.! Can u help please!x
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Try a bicycle pump or go to the local petrol station but be careful you dont over fill the inner tube. Or you may have a problem with the inner tube you can buy inner tubes from www.buggypitstop.co.uk
Posted on Feb 12, 2010
6ya staff
SOURCE:
FLAY TIRE ON MY BUGABOO IN VACATION IN DAN DIEGO HELP WHERE TO GO?
Any bike shop will do! Tyre and tube are a standard size used on a lot of kiddy bikes. Valve is same size as a car so any gas station air line can inflate it. Bugaboo recommend 15 psi / 1 bar. I run 25 to 30 psi.
Jul 29, 2011 | Bugaboo Cameleon Jogger
My bugaboo's not been used for a while and so the tyres are flat. i now need to use it again, but as there's no bond between tyre and wheel, i can't inflate it....help!!!
Tyre will be loose on the rim when deflated the problem is Bugaboo don't put a lock nut on the valve stem so it can pop down into the wheel when you try to inflate it with that joke of a pump Bugaboo provide. Best option is to just pop down to your local bike shop. Next best is to go to your local gas station as the valve is the same size as a car valve. Squeeze the tire tightly at the valve stem pushing it out as far as you can so you can fit the air line. Bugaboo recommend 15 psi / 1 Bar this is way to soft and I always inflate to 30 psi / 2 Bar. Try somewhere between the two as it's a compromise between ease of pushing vs softness of ride.
May 19, 2011 | Bugaboo Cameleon Jogger
The tyre keeps going flat. The valve on the inner tube was replaced and the tyre pumped up, but by the time I got the tyre home it had depflated again. There was a worn area on the inner tube and there...
Not a guru on Bertini but most strollers with pneumatic tires use standard tyres and tubes as used on kiddy bikes. I get tyres for Bugaboo's at my local K Mart. The size should be on the side wall of the tyre.
Apr 23, 2011 | Baby Gear
My bugaboo frog that i bought 1 month ago tips towards the side of the inflatable tires,i ve got the pump but it really doesnt look like its working,what should i do ?
The Bugaboo pump is a plastic joke and a bad one at that. Most Bugaboo's have the same tyre valve as a car and a car foot pump from your auto shop or department store will be cheaper and faster. If you want a more portable pump check out your local bike shop they have far better ones available. Very old Bugaboos have the smaller bicycle valve the newest Bugaboo's now have foam filled tires. Once you've pumped it up check for leaks, just unclip the wheel and stick it in a tub of water. If you have bubbles you need to fix the tube,
Dec 15, 2010 | Bugaboo Frog Stroller
I have lost the pump for my Bugaboo Frog, both of the tyres are completely flat. Where can I buy a new pump? Thanks, Paul
Dec 13, 2010 | Bugaboo Frog - Black Stroller
I needto pu air in the tires
There is no air in the tires. They are filled with foam and there is no way to add foam. If you are having a problem with the tires then I suggest you contact the manufacture. You have a 2 year warranty. Here is a link to their website. http://www.bugaboo.com/home Here is their contact information as copied from their website.
Call us toll free: 1-800-460-2922
Email us: [email protected]
Fax: (248) 738-6400
By Mail:
shop.bugaboo.com
2240 Greer Blvd
Sylvan Lake, MI 48320
Hours: Mon-Fri: 9am-8pm EST
Jun 19, 2010 | Bugaboo Cameleon Stroller
How do you pump up the bugaboo camelon tyres
the old tyres use a small bicyle pump or a foot pump
Nov 30, 2009 | Baby Gear
Bugaboo spare inner tubes need replacement 12" tubes
These can be purchased from most bicycle shops as they are a standard size, just ask for bent valves, makes the pumping up easier. Alternatively, you can get them from Bugaboo (www.bugaboo.com) but they will cost more.
Alternatively, if your model is a Cameleon (not a Frog or Gecko), you could buy the foam tyres (around £30 each) but would mean never another puncture.
I hope this helps.,
Sep 14, 2009 | Bugaboo Frog Stroller
My Bugaboo Chameleon bent
The best advice that I can give is to contat Bugaboo (www.bugaboo.com) who will be able to advise on the cost of a replacement chassis. Alternatively, you can purchase these from eBay most of the time.
I hoep this helps.
Apr 14, 2009 | Bugaboo Frog Stroller
Bugaboo Cameleon Jogger Logo
154 people viewed this question
Top Bugaboo Baby Gear Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
