Question about Mitsubishi WS-55411 55" Rear Projection Television
Cant adjust format on my tv picture is too big for screen
4 Suggested Answers
HDTV GURU
  • 261 Answers
SOURCE: Picture too big for the screen
If you are using any type of set top box weather it is a cable box or something along those lines, You are out of luck. The formating is controlled in whatever box is connected to tv. So to format the screen size keep this in mind. Cableboxes usually only let you adjust for 1080i and widescreen. But aspect is subjective to how they send the signal to you. Also make sure you hookup a HDTV cable box or I recommend Dish Network to this set because it is easy to operate the formating using the button on bottom left of remote. " * " STAR button is great. ALSO the DVR is larger and you can run the 2nd TV off the same box although it is Standard defination, the 2nd remote is very handy because it talks to the box via RF signals, which means no IR or line of site problems. Its awesome. If i can help you further. don't hesitate to email back. Thank you and have a good night. Jay
Posted on Jan 31, 2008
  • 1153 Answers
SOURCE: 50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Posted on Mar 17, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: sony big screen tv 57 inch kp57wv600 ghost
"ghost" are not television problem. This happens when a nearby structure "echoes" the signal from the station to your TV, there is nothing wrong with it.
Posted on Jul 01, 2009
The screen went big so we cant see the whole picture
hello!
looks like your TV picture in a "zoom" mode. Find "screen format" button on your remote control and set desired size. It, also could be named "format". Some models require to use customer setup menu.
Set format on "auto" mode, if possible.
Good luck,
Alex.
Dec 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
The picture is about an inch short at top and bottom whether it is in 16:9 or 4:3 mode. Can it be adjusted? Is there a service mode? I am a retired service man.
hi sir have you been already tried all the picture format at picture settings. automatic, super zoom and wide screen. try also in picture settings go to vertical shift adjustment and horizontal adjustment to adjust the position of the picture.
Jul 11, 2011 | Televison & Video
The picture is too big for my TV screen. How do i adjust the picture please.
PICTURE SIZE ON THE REMOTE IF CONNECTED WITH ANTENNA OR ORDINARY CABLE
OR THE PICTURE FORMAT CONVERTURE THAT COMMEC WITH YOUR DECODER THERE SHOULD BE A BUTTON ON THE REMOTE TOP CHANGE FORMAT
Feb 27, 2011 | Televison & Video
PICTURE TO BIG AT THE SCREEN.CAN NOT SEE THE PICTERS MARGIN AT THE SCREEN.HOW TO ADJUST(REDUCING PICTURE SIZE ON SCREEN)?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2)
Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
Aug 14, 2010 | Televison & Video
The picture is bigger than the screen... Picture is cut off and when I unscrewed the back of the tv I could see that the picture was showing perfect but it was to big for the screen... There's not a way to...
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
Nov 11, 2009 | RCA P52960 52" Rear Projection Television
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Jan 24, 2008 | Mitsubishi WS-55807 TV
Hooking up ati radeon 9550 to panasonic hdtv
You should be able to adjust the TV's format in screen adjustments. Use the remote that came with the TV.
Dec 28, 2007 | ATI RADEON 9550 256MB DDR 8XAGP W/TV&DVI...
Akai picture format
Service menu can be very destructive, what are you trying to adjust?
Dec 15, 2007 | Akai PTH5498 54" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
