I bought portable air conditioner everstar. its not as cold when i got it 2 years ago. Is there a way i can put refrigerant
    Scholar:
  • 133 Answers
You need to be State certified to buy and handle Refrigerant. Adding is not hard though. You need to remove the casing, install a screw on Watsco or Bullet valve in the suction line if there is no tap already installed, purge the air and moisture from your hose and manifold, attach it to the valve and add as needed. Use an Amp Probe to monitor the current draw on the compressor while adding. The Name Plate will give you its current rating as FLA (Full Load Amps) or RLA (Regular Load Amps). If you have the tools and refrigerant, look it over before doing anything else. Is the largest of 2 or 3 lines on the compressor cold? Be careful of the smaller one, it could be very hot. If the compressor is running and there is not much or no temperature difference, hook up your gauge and check the pressure. The type of refrigerant in the unit should be marked on one of its plates or labels. Add GAS not Liquid and go slow. Pay attention to the larger line temperature and your gauge. I normally charge to about 38 degrees depending on compressor performance. Use the scale on the gauge that matches the type of refrigerant used in your Air Conditioner and be careful not to overcharge or allow the compressor to draw too much current while charging. If you are not sure of something, turn it off and let me know, OK? Let me know how it goes for you. Good Luck! Roger
Posted on Apr 10, 2011
Everstar portable A/C unit MPM1-10CR-BB6 not getting cold
It seems low refrigerant issue need to refill refrigerant
Jul 26, 2016 | Heating & Cooling
The unit squeaks whenever turned on, no matter what level the fan is blowing (Lo, Med, or Hi). Started about a week and a half ago.
A rhythmic squeak sounds like either a fan motor bearing going bad or just vibration from the unit running thats wiggling something loose inside the unit.
Jul 23, 2015 | Everstar Portable Air Conditioner Everstar
Why does my portable ac not shut off when it reaches temp
It may just be running the fan and thermostat shut off cold until needed. Mine constantly blows unless I physically turn off.
hope that helps
Jun 18, 2014 | DeLonghi PAC85 Portable Air Conditioner
Why there is no cold air?
The compressor is not coming on and cooling the evaporator coils. It could be due to loss of refrigerant or something else.
Jun 05, 2014 | Everstar Portable Air Conditioner Everstar
Everstar Air Conditioner Portable has power to unit but screen is blank, no fan or cool!!
make sure you have power to it, try using another plug if not it sound like a bad board, the boards and screens can be ordered and replaced
Oct 22, 2013 | Everstar Portable Air Conditioner Everstar
Have a portable everstar ac model MPM2-10CR-BB6 blow strong but no cold air.
check temperature setting and the mode on cool if ok check the compressor is working with condenser fan if are working the unit has a loss of refrigerant . if the compressor is not working and voltage is correct may be the capacitor need replacement
Sep 03, 2009 | Heating & Cooling
Where do I find parts for everstar portable air conditioners
I just purchased a 11,000 BTU Everstar from Home Depot. Not sure if it's the same model that you have. Maybe check there? I bet an employee would be willing to open one of the boxes to answer your question. Just tell them you bought it there. :) Or call Everstar, of course. Good luck!
May 31, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
299 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
