Question about Cameras
I own a Maglite Single Led 3 AA Batteries .The innermost battery leaked and it is stuck to the barrel. I need to remove the bulb/led assembly to tap the battery either way. My question is : How do I remove the bulb/led assemby from the barrel. Thanks
  • 3,083 Answers
Some flashlights (especially led types) are not made to be disassembled, since the led's would nomally not need replacing within one's lifetime (they will last for decades or longer without burning out or going bad, due to their construction). The best thing you can try is to spray some WD-40 to loosen the solidified chemicals, and allow the battery to be shaken out. That's the only solution I know of, since trying to disassemble the lens assembly will result in destroying the lens assembly, from my experience.
I know this isn't the answer you're looking for, but it's the only solution I've found, and hope it helps.
Posted on Apr 10, 2011
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Battery stuck in 3 AA battery Minimaglite
The battery has to make contact with the bulb as well as the end cap, so if you take the end cap off and the batteries don't come out that end I recommend pulling the bulb assembly apart and taking them out that end. And the next time you put batteries in coat the outside of them (not the terminals) with electrical grease (like you put on car batteries) to prevent them from sticking in there again. Note: if both ends are removed you can use something like a screw driver to push the batteries straight through and out the other end.
Jul 04, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
MY maglite 2AA starts blinking
Unscrew the top head of the flashlight and check the contact points next to the bulb. if all else fails buy another one and take that one back and tell them it's defective.
May 10, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
