Question about Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord
How do you remove the quick connect blade holder and replace it? I have not tried to get it off yet.
  • 2,176 Answers
If you buy the replacement QuikLocKit assembly they have detailed instructions in it. But here is a simple method. Unplug the tool remove the shoe, remove the small retaining ring, and then the collar, twist the inner mechanism slightly to remove the pin and the rest pulls off. Let me know if you need more assistance.
Posted on Apr 16, 2011
Portercable 737 tigersaw can't keep a blade in the quick latch
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Mar 08, 2014 | Porter Cable Variable Speed All-Purpose...
Blade clamp removal
Use the proper tool .
Aug 28, 2012 | Televison & Video
Blade will not release on sawsall
ok first this is in the chainsaw category and since they don't make one,, I'll assume you mean a sawzall, if you have the quick release ( which is a joke and is a bad part ) your going to have to breal off the blade at the section that it reduces ( where it goes into the holder) unscrew the ringnut that releases the blade, and take it all apart. be careful there is a ballbearing sitting inside there that will roll right out and naturally get lost in the mix. once apart you can remove the last of the blade. Now if your really lucky, you can clean it,, lightly oil this piece , and reassemble it,, and it will work, I have 3 and have replaced that part on all 3 of them,, Now if its an older model that still has the set screw hold down,, Just unscrew the setscrews and remove the blade, ( some have 2 some just one set screw depending on the model
Jul 03, 2011 | Garden
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
Need to remove and then replace blade clamp on DW305 Type 1. how do you remove the blade clamp? I see two pins
Hello Hollister, on this peticular sawzall they are using a roll pin to hold the blade holder on. If you remove the blade clamp screw, you can move the blade holder back and forth on it. You will need to get a very small punch and drive it all the way out. Look at the picture below. You will need to remove (38) and (52). It will make it much easier.
I hope this helps. If you run into trouble, I'll walk you through it, just post back.
Dec 06, 2010 | Dewalt Saws
Trying to remove the center nut on the blade holder assy
it should be the old "lefty loosey, righty tighty" you will either have to figure a way to COMPLETEY secure the blade from spinning or use an impact wrench on it
Oct 18, 2009 | Garden
How to get the wiper blades off
these days the entire support and blade holder is replaced, gone are the days of the blade alone being changed. Typically, the arm disconnects where it connects to the blade holder.
Just change the whole thing, works better....
Oct 04, 2009 | 2005 Dodge Caravan
Milwaukee blade holder replacement
piece of cake. the number you need is 14-46-1011 and the cost is usually between 15 and 20 dollars. it comes with detailed instructions and a exploded parts list for this. About 10 minutes tops. If I have answered your request would you please rate this response accordingly. and if you provide me with city state and zip I will try and find one locally for you if in U.S.
Sep 14, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord Logo
298 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
