Question about Zonet ZEW2545 IEEE 802.11b/g IEEE 802.11n Draft 2.0 USB 2.0 Wireless Adapter Up to 130Mbps Data Rat... Pre-802.11n
There is an internet connection but it will not connect, say Aquiring network connection
    President:
  • 1,768 Answers
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Posted on Apr 10, 2011
I cant get my ne10 to connect to wifi
Try to reboot BOTH devices, remove power from Both devices and reboot. I'm not sure what a ne10 is? The "aquiring network adress" is it's try to aquire the IP address. If you power everthing down it should reset everything. You question isn't very clear. I don't know what "IT' is? "when i try to connect "it" to my web cube "it" just says aquiring network adress how do i get "it" to work properly please"?
Nov 13, 2012 | Samsung NC10-14GW Notebook
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
I have a problem with a internet connectivity in the task bar its showing aquiring network address
Acquiring network address (Limited or no connectivity)
1.Check whether you are typing the correct key
2.Remove the preferred networks
3.Disable WLAN/LAN and Enable it
4.Assign static IP address in the range of modem
5.Add the network manually with the security settings
Apr 04, 2010 | Lenovo ThinkCentre® A51 PC Desktop
Problems connecting, stuck on aquiring network/renewing IP addres
i want to down load the mother board drivers and utilities c.d,how will down load
Sep 01, 2009 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Cant connect laptop to internet
Hi!
I think that maybe you are using and incorrect password to connect to your wifi network.
Feb 18, 2009 | HP Compaq Evo n610c Notebook
No ip address
when you say ip/config you mean wifi properties and internet protocol properties right ?
if so select obtain ip address auto and select obtain dns auto.
if thats not what you mean...goto control panel ..open network connections...click on ur network connection ...in the list at left select change settings for this connection...in network properties scroll to internet protocol..double click to open..select obtain ip auto and obtain dns auto.
there are other ways to fill in fields but you need relevant info..
there are programs which can show u ip's but most require a special driver.
incidently if you choose ip and dns auto you will not see ip address but when connecting to network you will see aquiring ip address please wait.
if for some reason you still cant connect go to a place where you know have free internet access and connect there then net connection will be configured
Jan 25, 2009 | Computers & Internet
Wireless Connection to Internet
if you have you network up and running and connected, then on taskbar on the right at the bottom of the screen...... you should have a wireless connection icon like one computer icon, right click on this choose .....view available networks and then make sure yours is choosen.....then click connect the first time you may have to put your ssid or pass phrase in again.....once that done it should say aquiring network address or connected.
i hope this helped if not let me know.
Oct 11, 2008 | Computers & Internet
WRT54G
check the cables. the cable coming from the modem should be connected to the internet port of the router.
power cycle. turn off all the devices then turn on the modem first. wait for the modem to boot up before turning on the router and the computers.
if you are using a wireless computer, make sure that you are connected to the signal coming from your router. customize (change ssid, wireless channel) your wireless settings if still set to default and try to connect again
hope this'll help you
ciao
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
Wireless internet problem,help please
Please disable firewall if you have on your computer and then check for the issue
Regards
Syed
Jul 18, 2008 | Dell Inspiron 2200 Notebook
Can't connect to internet
It sounds like the driver for the USB network device is not loaded correctly. So, you'll need to reinstall it from scratch. Unplug everything, install the software, then reattach the usb cable to the PC.
The other thing is, did you DISABLE the network adapter that was already in your PC when you added the USB network adapter? If not, you need to do that. If they are both active but only one is connected, the system could still be trying to use the other network adapter and tying up the resources in the process.
Jun 23, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Zonet ZEW2545 IEEE 802.11b/g IEEE 802.11n Draft 2.0 USB 2.0 Wireless Adapter Up to 130Mbps Data Rat... Pre-802.11n Logo
278 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
