Question about Metz 48 AF-1 for Sony Alpha TTL Flash
My metz flash 48 Af-1 for a sony DSLR flashes an "Er" in the zoom mode along with .03mm flashing. This happens when the flash is turned on and in all modes
  • jeffc6910 Apr 12, 2011
    Thanks for the first suggestion.
    I still get Er blinking also with .3mm blinking when I turn on the camera. If I hold the mode and a select button I will get an rES will flash then go back to the Er blinking. In the Manual mode (M) I can change the setting but the Er still blinks. I've tried various combinations with different cameras and different lens.I keep getting the same Er blinking with 0.3mm blinking.
    JeffC6910@netscape.net
  • Ninel Sep 01, 2013
    Here is my solution. I have same problem and solved with a little hand hit on the zone when i supposed that the motor zoom is. It worked for me. This error is because the motor zoom is jamed. Try hit softly when the unit is on.
  • 17,970 Answers
According with the manual, depending on the system, the extended zoom mode is supported for lens focal lengths of 28 mm or more (35mm format). The camera must be equipped with a CPU lens and be able to transfer data on the lens focal length to the flash unit.
In extended zoom mode the zoom position of the main reflector is reduced to one level below the focal length of the camera lens. The resulting expanded and broader light coverage provides additional dispersed light (reflections) inside rooms so that a softer flash illumination is possible.
Example:
The focal length of the camera lens is 50 mm. The extended zoom mode sets a 35 mm reflector position on the flash unit. However, 50 mm continues to be shown on the display.
Setting procedure
• repeatedly press button combination "Select" until "Zoom" appears in the display and "Ex" flashes. The required settings can be applied using the ( + ) and ( - ) buttons.
- When "Ex On" is displayed, the extended zoom mode is activated.
- When "Ex OFF" is displayed, the extended zoom mode is deactivated.
The setting takes effect immediately. After about five seconds the display stops flashing and the setting is saved automatically. After activation of the extended zoom mode "Ex" appears in the display.
Keep us updated.
Posted on Apr 10, 2011
Metz flash sony nex camera
Sony NEX 6 has an ATG/Sony's Multi-Interface-Shoe.
Let's hope the Metz 58AF-2 Flash is made for Sony/Minolta, which has an old Minolta's hotshoe.
Contact Sony for the adapter.
Or just buy the Promaster Sony Multi-Ineterface Shoe Adapter, it less than Sony's.
atdlee@netzero.com
Dec 29, 2012 | Metz MZ58321C 58 AF-2 Digital Flash for...
I'm new to photography and have a Nikon D-50 with a Metz 58 AF-1 digital flash. Where can I find a users manual?
Metz 58 AF-1:
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_58_AF_1_digital_Nikon_D_F_NL_GB_I_E.pdf
Nikon D50:
http://support.nikontech.com/app/answers/detail/a_id/13644
Sep 04, 2010 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
METZ 48 af-1 N "err at the place where zoom value displays in LCD
Is seem a little bit strange but it worked for fine me
The problem is mechanical. The zoommirror in the flashhead is stuck. Mostly it is a minor opstacel. That is the reason that sometimes the problem is solved by placing new batteries. The zoommotor has a little bit more power en can overcome the minor opstacel.
When the zoom is blocked it cannot be controled by the stering software and therefore it gives an error.
Solution
1. remove flash from our camera (power off).
2. knok with something hard, I used my fingerknuckle, on the side of your flash head.
3. repeat that for each side (i knocked twice on each side).
4. place our flasher on the camera and power on both.
5. If the problem isn't solved repeat it
It worked for me the first time.
Jan 26, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Err at the place where zoom value displays in LCD
Though I am sure your solution may have been fixed already.
The guide that the reflector moves along for the Zoom.. has probably been knocked off position (either the guide/rail or the "runner" of the reflector).
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Metz 48 AF-1 for Sony Alpha TTL Flash Logo
227 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
