ASUS X83VB-X2 Notebook Logo
Anonymous Posted on Apr 09, 2011
My -ASUS X83VB-X2 win7 64- was working perfect but suddenly 3 very bad things happened: 1) The web cam is not working any more, did disapear and can not even be found in the Devices Admin., 2) The battery charger is not working. I tought it was the battery itself, so I bought a new one but still does not charge. 3) In the Devices Admin. now I found an unknow device and going through its properties>details in the value window can read: ACPI\ITE8708 *ITE8708 I have reinstalled the win7 several times trying to fix the problem but it is always the same and nothing good happens. As far as I can think it could be some corrupted drivers or anything like that. Thanking you in advance. Best regards, Jairo R.
Julie Endres
Level 2:
Sergeant:
Champion:
  • Expert 209 Answers
  • Posted on Apr 09, 2011
Julie Endres
Expert
Level 2:
Sergeant:
Champion:
Answers
209
Questions
Helped
34756
Points
620
I agree, it is most likely a bad driver. When you go into the device manager, do you see any exclamation marks in yellow triangles? That would indicate a hardware problem. If you go into the offending hardware component, there should be a button that says whether or not the device is working properly and also and update drive button. Try updating the drivers and see if that works. The webcam could be reinstalled using the disk that came with it. The driver may not be Windows 7 compatible so if you tell me the make and model, I could try to get an updated driver for you.
Let me know.
I have a X83VB, the screen went white.When start up is fine, I can unlock it then from there the screen goes white and I cant see anything. How can i fix this without losing everything? or can I ?
Have you tried a System Restore? If you connect a External Monitor is there any change? Is the HDD LED blinking? Can you boot to Safe Mode? What preceded this issue?
F keys not working
go to your computer technician that problem is not a software problem
cause of that maybe u use laptop when your hand is wet,
hard pressing the keys
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
2answers
Need driver for ASUS X83V Notebook so I can get on internet to update all drivers
All the drivers for this model can be found here:
http://support.asus.com/download.aspx?SLanguage=en&m=X83Vb&p=3&s=148&os=8&hashedid=n%2fa
Take note, drivers available for this model is only limitter to Windows Vista
1helpful
Asus x83vb-x2 factory reset.
Hi
please try this
press the power on key as well as the F9 key
they may take you into the factory restore consol
then follow the on screen instructions
if you have the option please save any data you want to keep before doing this
as a complete factory restore should take the laptop back to as when you ist purchased it
many thanks
please let us know if this has helped you
so that we may be able to help others
Laptop powers up but a blank screen shows with two green lights showing up top whats the problem
PLug the laptop into an external monitor to see if you get video to the external screen.  You should have a vga port on your laptop, connect it to the laptop and then turn it on.  If you see video the onboard video card on the laptop is fine and most likely you have a bad lcd.  On the other hand if by "powers up and then goes to a blank screen" you mean its posting you see the asus splash screen and instaed of going into windows you see a blank screen.  in that case you mos likely have a bad hard drive or corrupt operating system.  You can test the hard drive by downloading dft and booting from that cd.  here is a link to dft http://www.hitachigst.com/support/downloads/#DFT
1helpful
I put a request for help and got an answer, but now I want to send more details to keep trying to find a solution, but every time I want to send there is a message saying "Please use only legal...
Legal characters are generally the letters A-Z and numbers 0-9, as well as a few general symbols such as , . / etc.
******* characters are such things as different fonts that cant be displayed or hidden characters. This can happen if you are cutting and pasting from a different source, it may be importing ******* characters that you cant see, but are part of the paste. Try deleting the whole input are and typing your answer with no cut and paste.
Laptop Hickups
Your LCD panel is bad, replacing yourself will cost over $100 depending on the quality of the replacement panel.
Jul 20, 2010 • ASUS Laptop
3answers
My Asus X83Vb is running on Windows 7. The CD drive gets stuck or freezes whenever I try to burn a CD.I'm starting to believe its a driver issue because the laptop was made for Windows Vista. I'm running...
Normally there should not be the drivers issue with CD ROM because windows 7 has almost the drivers for hardwares available.
To make sure you can go to device manager and uninstall the ATA channel1 and DVD cd ROM drive drivers after clicking on them.
After rebooting the drivers will be reloaded and reboot the system once more.
If then also the issue is not resolved try with soft eject (right click on drive icon and click eject).If then also the issue persists then the issue is with hardware.
Thanks
Apr 05, 2010 • ASUS Laptop
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
