Question about MSI Wind U100-280US Netbook
How to change languages on msi laptop - MSI Wind U100-280US Netbook
I have a MSI win notebook want to change language from polish to English
Go to Control Panel.
Pick Language as English.
Go to Keyboard and Pick UK or USA keyboards.
Sep 26, 2014 | Computers & Internet
Change language regional windows english
Open the Control Panel, select Regions and Language, select Location. Check other settings.
May 08, 2013 | MSI Wind U100-280US Netbook
I have MSI Wind U100-280US 10-inch Netbook that its language is hebrew. how can i change it into english version of windows. because i bought it i israel. i cant understand its language popups,start menu,...
You need to do the following:
If it's windows 7, Go to the windows button, click it and then click on control panel (the first menu item in the third section of the grey panel). In this part you'll see an icon with a globe and a clock. This is the Clock, Language and Region section. Click on it and that will bring you to the detailed settings, with three icons: a clock and calendar, a clock and globe and just a globe.
Click on the clock and globe to access the region and language settings. The first drop down menu is the language setting, which you should change to English (United States)
Hope this helps.
May 17, 2011 | MSI Wind U100-280US Netbook
My netbook is in polish..how do i get it into english
change these settings go to your 'control panel' and select 'regional and language options' then click on the 'keyboards and languages' tab and 'add' your country. Let me know if this helps. Have a good day...Here are some great source ...">change these settings go to your 'control panel' and select 'regional and language options' then click on the 'keyboards and languages' tab and 'add' your country. Let me know if this helps.
Mar 22, 2011 | MSI Wind U100-030US Laptop
Need to change from Dutch to English language to get started.
Assuming you have Windows installed.
If you go to Control Pane, select Regions and Language. Set up as you require.
Hope that helps.
Feb 20, 2011 | MSI Computers & Internet
My sons netbook which we have just started up is in French and we,re sttuck as how to change it into English. Can you help?
Go to control panel, select Region and Languages. Move across the sub menu and select Keyboards and Languages.
Merry Xmas.
Dec 25, 2010 | MSI Wind U100-030US Laptop
My new netbook is in French. How do we get it into English.
Well first of all you may Open Regional and Language Options in Control Panel, to open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options after then you may select English Language. The Key Settings button is available only if you have added multiple languages or keyboard layouts.
Good Luck!!
Thanks for using FixYa!!
The @ button on my msi u100 does not work how do i get or do i have to combine with other button
unfortunately there's no shortcut key/ code for this character... or you could try this:
To customize key sequences for input languages
  1. Open Regional and Language Options in Control Panel.
  2. On the Languages tab, under Text services and input languages, click Details.
  3. Under Preferences, click Key Settings.
  4. In the Advanced Key Settings dialog box, under Hot keys for input languages, click the action for which you want to change the key sequence, and then click Change Key Sequence.
  5. If necessary, select the check box to enable an action, and then click the key sequence you want to use.
  6. Click OK four times.
Notes
  • To open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options.
  • The Key Settings button is available only if you have added multiple languages or keyboard layouts.
Nov 08, 2009 | MSI Wind U100-030US Laptop
I have a msi u100 and the keyboard keys do not relate to the correct symbols? for example if I use the pound symbol it puts the hash key???
 Wrong keyboard mapping.
Start / Control Panel / Regional and Languages Options / Languages / Details / in there select the keyboard arrangement you want - most likely the english EN one.
Nov 04, 2009 | MSI Wind U100-030US Laptop
Bios on my ibm msi ms6188 is on german language , and i want to change on english
get the bios info corrrectly, go to the manufacturers site and download the upgrade bios software to flash ur current bios.
Dec 13, 2007 | IBM MSI MS-6188 (49P3492) Motherboard
MSI Wind U100-280US Netbook Logo
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
