Question about Singer 3116 Simple
My needle wont pick uo bobbin thread - Singer 3116 Simple
  • 415 Answers
Check the needle. Is it the right size? Right type? (for the fabric). Put in correctly? If sewing though thicker material you need a bigger needle.,
Check the bobbin tension and make sure it isn't too tight. Also make sure it is wound correctly. Does it pull through by hand when you pull on the thread?
Then check the top tension and make sure it isn't too tight or too loose.
Those are the most likely problems.
Posted on Apr 09, 2011
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
NEEDLE THREAD WILL NOT PICK UP BOBBIN THREAS
you should try these needle called the organ needle they have 10 pcs. HAx1 130/705H 15x1 size 100/16 these needles are longer and strong . Maybe the one you have is too short
Oct 19, 2014 | Elna Quilter's Dream 6003Q
Why wont my needle pick up my bobbin thread
1. Either the needle is smaller than required and does not reach down enough to loop the bobbin thread.2. Or the bobbin thread is not kept out of the shuttle and does not make a loop with the needle thread.
Apr 05, 2012 | Brother Sewing Machines
Wont pick up bobbin thread
1.check needle to see if it's bent or blunt end
2.check bobbin & bobbin case for lint or loose thread
3.could be a timming problem- would have to be serviced
Jul 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Oct 02, 2009 | Singer 7444 Mechanical Sewing Machine
Brother computerized c s6000i will not pic up bobbin thread
Have you got the bobbin in the correct way around, also have you put the needle in correct with the groove in the front of you.Are you using the correct bobbins,if yes to all these your machine has thrown it timing out in the bobbin.and needs to be looked at.
Jan 16, 2009 | Brother CS6000i Computerized Sewing...
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 3116 Simple Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
