Question about Dishwashers
Fisher & Paykel DW60. Fault: Will not start regardless of program selected. E.g. if "heavy duty" pressed, only light will flash, if "normal" is pressed, only this light will flash etc. All hoses (water and drain) have been checked and no crimps or blockages found at either end. All usual methods tried (e.g. cleaning strainers and filters, turning power off for a while etc). Finally, while lights are working, the machine makes no noise at all when a pogram is selected.
  • 883 Answers
SOURCE: machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
Posted on May 30, 2007
  • 833 Answers
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: when turned on only makes humming sound wont start
Hi, A common occurance with these units is the wash motor may become "stuck". Don't worry...yet. It's usually fairly easy to fix. Since you stated you've clean the filter I assume you know how to remove the filer insert and then the screen below the lower spray arm, right ? If so, remove it and in the sump to the left will be a "well" leading to the pump impeller. Using a 5/16 nut drive screwdriver or small socket set give it a twist until it breaks free and you should be back in business. Keep in mind if the problem continues to re-occure, you likely need an impeller seal kit. We'll deal with that later if needed. I Hope I've been of some help. Good Luck
Posted on Oct 29, 2009
pride applia
  • 232 Answers
SOURCE: My fisher and paykel nautilus dishwasher isn't draining properly
remove strainers and clean and try again
Posted on Dec 27, 2009
Fisher & Paykel DW60 dishwasher will not start. All LED's stay on and program cannot be selected.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 08, 2015 | Fisher and Paykel Dishwashers
F&P Dishwasher Fault
Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
Refer manual
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Mar 18, 2014 | Fisher and Paykel Dishwashers
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
Mar 03, 2012 | Fisher Paykel Eco IWL16
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel GW709NZ will not fill
Hi just read your posting.Your Error Code is 49.This means you have a Water Valve Fault.Would you like me to guide you throe the testing and repair of your machine?If you do then have you or can you borrow an electrical test meter to test the water valves?Please reply and tell me how you would like to proceed.Looking forward to your posting.
Jul 19, 2010 | Fisher and Paykel Washing Machines
Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Nov 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
198 people viewed this question
Top Dishwashers Experts
Owen Barnes
