Question about Samsung DVD-V3500 DVD Player/VCR
My Samsung DVD-V3500 keeps poping the fuse located on the inside.
  • Samsung Master
  • 506 Answers
There would likely be a short-circuit in the power supply causing the fuse to continually blow each time it is replaced. Either a faulty IC regulator, and/or several electrolytic capacitors, and/or leaky/short-circuit diodes. This would require attention by an authorised service centre, but it could be expensive (this cannot be repaired by the consumer as some of the components inside are virtually impossible to obtain off the shelf).
Nevertheless, you can submit the unit to a workshop, obtain a quote on the repair cost(s), and a second opinion about the unit itself, before going further. This allows you to make a decision on the information provided by the service technician at the time. Up to you.
As I have mentioned before, Samsung has a habit of using unusual parts in their switchmode power supplies; these parts are often of a strange value or voltage rating, and are unobtainable off the shelf to the public - hence the workshop suggestion above. The PSU may require modification or replacement, but this can only be determined by a technician.
Posted on Apr 10, 2011
I forgot the password to my samsung dvd player V3500. I want to reset it for no parental controls & i do not have the user manuel
If you forgot your password, press power on from a cold start
with no disc in the unit. Press the REW and F.F buttons
simultaneously on the front panel for 5 seconds. The "reset ok"
message will appear. Press the POWER button and the
DVD-VCR will go to the "Auto Setup" mode. (See page 13)
You can also download the manual on the link below. Just scroll down to product detail to download it.
http://www.amazon.com/Samsung-DVD-V3500-Progressive-Scan-DVD-Combo/dp/B00008N6YJ
Good luck
Nov 20, 2010 | Samsung DVD-V3500 DVD Player/VCR
Samsung DVD-V3500 VHS/DVD player used to "remember" time when we lost power, now it doesn't. I assume there's a back-up battery, but it's not noted in the instruction manual nor do I see a cover or...
If it has a battery it will probally be inside under the cover. It coulbe replaceable or it could be a soldered in lithium (typically button cell) which last about 5 years.
Mar 15, 2010 | Samsung DVD-V3500 DVD Player/VCR
1.6A250V fuse blows on V3500 power circuit board
Your DVD combo use a Switch Mode Power supply.
If you want to give it a bash here is a good guide that explains how they work and how to trouble shoot. http://www.repairfaq.org/sam/smpsfaq.htm
but ...
in 95% of the cases it is a shorted switchmode power transistor and other semiconductors, open fusable resistors, other bad parts. Note: actual cause of failure may be power surge/brownout/lightning strikes, random failure, or primary side electrolytic capacitor(s) with greatly reduced capacity or entirely open - test them before powering up the repaired unit.
Mar 01, 2010 | Samsung DVD-V3500 DVD Player/VCR
Samsung DVD-V3500 Remote control code
SOME UNIVERSAL REMOTES HAVE AN AUTO FIND FEATURE FOR THE CODE, READ THAT PARTICULAR REMOTES USER GUIDE FOR DETAILED INFO. YOU MIGHT ALSO TRY COPYING AND PASTE THIS QUERY (Samsung DVD-3500 Remote control code) INTO YOUR GOOGLE SEARCH WINDOW THE RESULTS PROVIDE VARIOUS SITES WITH MANY CODES FOR SAMSUNG EQUIPS
Jan 11, 2018 | Samsung DVD-V3500 DVD Player/VCR
No power
Sounds like you have a capacitor problem.You need to open the dvd player up and check all the capacitors located on the power board.Make sure it is unplugged and be careful.There will still be some charge inside the unit.
Aug 31, 2009 | Samsung DVD-V3500 DVD Player/VCR
Vhs tape stuck inside Samsung DVD-V3500 dvd/vcr combo
Go to this web site. It will give you some guidance on how to remove the tape. I had the same problem and managed to get the tape out with out much trouble. My DVD V 3500 blows fuses like they are going out of style. Go to http://www.fixer.com/ for help.
Mar 28, 2008 | Samsung DVD-V3500 DVD Player/VCR
How to record DVD to VHS
Page 54 in my V3500 manual states:
"Recording from the DVD player to the VCR is not
possible."
Dec 24, 2007 | Samsung DVD-V3500 DVD Player/VCR
Samsung DVD-V3500 DVD Player/VCR Logo
113 people viewed this question
Henry  Thomas
Henry Thomas
