Question about autozone.com
I have a 2002 T-Bird that I took to a Ford Dealership because the air condition was not working. They charged me $1,700 for a new compressor. When I got it back, it still did not work. They said that there was 2 freon leaks and they fixed them but now they say that there must be another leak in the line and want $800 to fix it. What does the line look like and shouldn't they have put a new line in?
    President:
  • 2,187 Answers
There are two lines that they could be referring to. They are metal pipes which is thin in diameter, kind of like a straw. They are covered by thick insulation in most of their length.. Both of which runs from the condenser (the coils found in front of the radiator) to the AC compressor located at the engine and would stop for a moment to a small knob/screw like part where you charge the freon then goes to the inside of the car to the evaporator found underneath the dashboard.
You can do a simple test yourself by putting soap suds on the these. You should be able to see bubbles being made where there is leak. If the pressure of the freon dropped after changing the compressor then it may be a leak. If you hear the clicking sound after turning on the aircon, the fans blowing, you may just need to have the evaporators cleaned which is a cheap fix.
Posted on Apr 09, 2011
What do I do when I change A/C compressor on 2001 Ford Expedition Eddie Bauer
No, don't add any Freon before changing out compressor.
Unfortunately, due to the multiple places where leaks can occur, and the concern of releasing Freon into the atmosphere when opening up an air conditioning system, this work SHOULD be done by qualified personnel with appropriate tools. Auto air conditioning is NOT in the realm of "Do It Yourself" any longer.
It would be best if, after installing the new compressor, you took the vehicle to an auto center that services auto air conditioners. They can draw a vacuum into the system before filling the system with Freon. This will give you the best fill with Freon and will reduce and/or eliminate condensation in the system.
Also, if you're opening the system to air anyway, to change the compressor, you should consider changing the drier in the air conditioner line as well.
Jun 20, 2014 | Denso 1997 Ford Expedition A/C Compressor
How to take out air condition compreser out of a2001 mercury sable
have dealership discharge airconditioning system.you need to disconnect refrigerant lines going to the AC compressor you probably need refrigerant lines disconnect tools to remove disconnect refrigerant lines.you need to remove drive belt.and safely raise support vechicle remove tire or wheel work from under vechicle you have to loosen AC COMPRESSOR bolts then remove AC COMPRESSOR.be sure pour old refrigerant in a measuring cup so you can pour same amount new oil in the new compressor.add couple ounces if old AC COMPRESSOR dry.
Feb 11, 2013 | 2001 Ford Taurus
The A/C in my 2002 ford Taurus SES (about 185,000 miles on it) went out about a month ago. I had the mechanic at the Midas shop in Billings take a super-quick look at my car about 2 weeks ago because there...
if the compressor bearing seized or fell apart than that would cause the belt to break or fall off. You cannot bypass the a/c compressor with a shorter belt. You can either replace the compressor or get a compressor bypass pulley but then you will not have a/c ever again until you install a compressor.
Aug 16, 2011 | 2002 Ford Taurus
The back end of my 2002 Bravada suddenly sags. i have been told is it not the shocks but the air compressor. how much is the cost to repair this problem, at a dealership?
The first thing to do is establish the condition of the compressor. Using jumper wires, connect the compressor to direct battery voltage. Make sure you don't have a blown fuse. If the compressor works with direct voltage, then the problem lies elsewhere. Make sure all the air lines are connected and in good shape. Check to see if the level sensor under the rear of the vehicle is getting vovltage. If your compressor doesn't come on when you apply direct voltage, then it will have to be replaced. Shop around for the best deal on a new compressor. The dealership will charge you a tremendous markup.
Dec 16, 2010 | 2002 Oldsmobile Bravada
2009 toyota sienna, a/c doesn't work. i have lready replaced the compressor,clutch,relay, expansion valve and drier....still not working....even the toyota dealership her in las vegas is puzzled why it...
does the fan blow air in the cab i know its not cold but it is air? does the air lines compressor sweat? it may be the air conditioning button in the car where turn ac on off is not sending signal to compressor to turn on compressor and check the air ducts make sure they routing the air correctly to the cab check to make sure a ac system is not over charged if it is over charged will not send out cold air use a tire gauge should be around 40 psi i believe but check with dealer make sure my psi is correct hope this helps if dont fix repost and think somemore ideas
Sep 15, 2010 | 2004 Toyota Sienna
Honda CRV 2002 air conditioning not cold and was just charged,
Did you have compressor checked to make sure it is not the problem? Or did you just charge due to lack of cool air? Some parts stores can check it. Garages too.. If not the prob let me know..
Jul 06, 2009 | 1998 Honda CR-V
Air conditioning 1996 Ford Explorer
You were not clear, but I assume the compressor runs OK. If not, troubleshoot the electrical to the compressor. Did you replace the orifice tube while it was discharged for service? If not, then check the pressures. If low side pressure is high the tube might be plugged, especially if you truly had a bad compressor. In a properly working system the line should be cold on the evaporator side of the orifice tube when properly charged. If compressor runs, system properly charged and that line is warm then suspect a plugged tube.
Jun 30, 2009 | 1996 Ford Explorer
Worked on the solenoid thing on the sidewall and now the air conditioner will not run. Did I not hook something back up?
Broke down and went to Ford Dealership. They ran diagnostic testing on the air conditioning system to find out that it was a switch that controlled recycling of the compressor... $82. later it is fixed and working.
May 01, 2009 | 1995 Ford F150 Styleside Regular Cab
I have a 2002 Oldsmobile aurora. I had problems with the air conditioning. The air conditioning would sometimes turn on and sometimes it would not turn on. I took it to my dealership and a new...
That compressor is now 9 years old if done in 08 it may have leaked out the freon check to see if gas is still in the system if it still has gas check fuses if there good check the plugs on the compressor/cycling switch for broken/corrosion/wires/connection and fix otherwise if all is good the compressor clutch coil may have failed good luck and check all electrical things and gas first before going further a quick push in on the pin on the ac line at the tank low pressure side will give you the gas confirmation a high escape sound like when you press your tire valve to release air will tell you if it is still properly freon charged turn your face away when doing this or wear safety glasses then if it's ok start the electrical process a guy with mechanical knowledge would be a big help a cheeseburger deluxe and a beer will keep him happy Stephen
Oct 03, 2017 | Oldsmobile Aurora Cars & Trucks
Air conditioning quit
Prior to charging the system, did you vacum it down? If you did not when there becomes a load on it the low pressure switch will kick the compressor off to avoid damage to the compressor.
Jul 08, 2008 | 2001 Ford Escort ZX2
Open Questions:
autozone.com Logo
23 people viewed this question
Top autozone.com Computers & Internet Experts
David Payne
David Payne
Are you an autozone.com Computer and Internet Expert? Answer questions, earn points and help others
