Question about Polaris 800 Twin Sportsman Ride on Toy
Wheels are worn through on my sons 24 volt polaris. i was wondering if there were any other wheels from the 24 volt line up that would fit to kind of do a little customizing on his 4 wheeler as a suprise
    Genius:
  • Polaris Master
  • 1,508 Answers
I can get you replacement sof the original ones if you are still looking
Posted on May 23, 2012
2 Suggested Answers
  • 3 Answers
SOURCE: electrical wiring diagram is required for Peg
Here is a link to the wiring diagram http://peg-peregoparts.com/diagram.php?num=IGOD0511#W
Posted on Dec 02, 2010
2010 polaris sportsman 300 awd is not in awd in reverse is this normal or do I have a problem
Push the yellow button on the hand area. On some models, it engages 4 wheel drive
Jan 06, 2014 | Polaris ATV
Sons polaris 800 twin sportsman two seater 24 volt was riding fine in all gears and now he can only go in reverse
this could either be the that one of the motors has died or the connecter on the bottom of the shifter switch has come disconnected, i'd probably check the shifter switch first, you'll have to take out the battery and then the black plastic panel by the battery this will give you access to where the shiter assembly is and then underneath the four wheeler you'll have to remove the two screws that hold the shifter assembly in and then verify that the two plugs are plugged into the bottom of the shifter assembley
Apr 21, 2012 | Polaris 800 Twin Sportsman Ride on Toy
We purchased a used Polaris serial number IGOD0027. It has a brand new battery and is fully charged but there is still no power. We hook up the battery and nothing. Is there an on/off switch or something...
check the battery with a multimeter and make sure that it is showing 24 volts, lots of time the battery comes disconnected under the yellow plastic housing
Jun 30, 2011 | Polaris 800 Twin 24 Volt Vehicle
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
My son purchased a mongoose 24'' XR75 from Walmart last summer. When we puchased it the back wheel was warped. Your company sent us another one. It is warped again and I want to replace it with a stronger...
Any good bicycle repair shop should stock a variety of wheels. Ask the staff and tell them what kind of riding your son does or better yet, take him along with you. A fun project if you can afford it is to build your own. Here is links to sites with good info:http://www.parktool.com/repair/byregion.asp?catid=56 and http://sheldonbrown.com/wheelbuild.html Hope this helps.
Nov 27, 2009 | Cycling
Battery run time to short
not realy as it will burn out the motors!
get a new battery
Jul 26, 2009 | Toys
Polaris 800 Twin Sportsman Ride on Toy Logo
114 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
