Question about GPS
I evidently burned it out by using the wrong type of dimmer switch. Where can I purchase a new one?
    Sergeant:
    Champion:
  • 209 Answers
GPS devices can be purchased at any local retail department store or computer store. They can also be purchased online.
Posted on Apr 09, 2011
How to fit dimmer switch
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
May 29, 2013 | Electrical Supplies
I installed a single pole rotary dimmer in my dinning room about a year ago. It controls a fan and a dimmer 4 bulb lamp. I used this fixture maybe once or twice a week, and only occasional times we used...
Rotary dimmers are not normally suitable for fan control plus not all types of lamps are dimmable , so used wrongly a dimmer could catch fire.
Steve
Nov 07, 2011 | Electrical Supplies
I changed the light bulbs in the fixture it controls, now it does not work. What is wrong?
This switch is designed to dim incandescent lamps. It has nothing in its description about being used with CFL (compact fluorescent lamps) types. If you are attempting to dim standard CFL types, it will not work.
CFL's are available in both dim-able and standard types. As you may have guessed, only those marked as "dim-able" will work with a dimmer switch. Dim-able CFLs cost slightly more than standard CFLs but may be controlled by any switch. Dimmer switches may only control incandescent and other type lamps that specifically state they are compatible with dimmer switches.
If you are attempting to dim incandescent lamps, make sure that you are not trying to dim lamps with a total wattage greater than the dimmer can handle. Most dimmer switches are rated for 600 watts, if you have two dimmer switches under one wall plate, the wattage rating drops to about 500 watts. This de-rating is because of the heat the switches create. There are dimmer switches that can dim more than 600 watts, but the price skyrockets for a 1000 watt dimmer, and keeps climbing.
If your wattage is within the limits of the dimmer, check the bulbs. If they are ok, the dimmer may have failed and require replacement.
If you found my reply helpful, please rate it "4 thumbs up". Good luck & thanks!
Aug 16, 2011 | GE 18027 Dimmer Toggle OnOff with Slide...
I have 600 w lutron dimmer running 3 40 w incadesant lights. they start blinking like strobe lights. change bulbs and it goes away
If your dimmer was working correctly in the past, and suddenly started doing this, then your dimmer is probably gone bad.
If this is a new installation, the wiring could be wrong, or the dimmer could be wrong.
For example you purchased the companion or accessory dimmer rather than the main dimmer.
Or the wiring is put on the wrong screw.
If this is a new installation, add a comment and fill in the information and I can troubleshoot.
What is the model number of your dimmer.
For example the Maestro MIR600.
Are you replacing a single-pole switch or a 3-way switch?
Are you using 2 dimmers in a 3-way application?
What color are the screws on your dimmer?
What color are your wires and which screw do they go to?
Nov 04, 2010 | Lutron Electrical Supplies
I bought a Lutron Dimmer Switch and there is a light on in the background when I turn the switch off. It is suppose to be that way. It seems to be hotter when the switch is off instead of hotter when the...
First off, if your dimmer is getting hot, then there is something wrong. This is dangerous. Do not leave that dimmer in the wall. Remove it.
1) A typical wall switch controls up to 1400 Watts. Look at the watt rating of your dimmer. A 600 watt dimmer will control up to 600 watts. If you have 600 watts on your dimmer, expect a shortened lifespan for that device. If you have more than 600 Watts, expect overheating and possible fire.
2) Lutron makes 1000 Watt dimmers
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
3) Type of bulb: Review the specs shown on link above because they show wattage, and they also show which light the dimmer is made to control
4) If your lights are on a 3-way switch, then dimmer has 3 screws and connects to 3 wires. If your wiring is incorrect, it might give symptoms shown above.
If your switch had 2 wires and you put those wires on a dimmer with 3 screws, it might be wired incorrectly.
Check wiring. Re-post a question if your are confused about details.
5) There might be a short in the circuit ... or in the dimmer ... replace dimmer with another one from Home Depot and see if symptoms persist. Disconnect ground wire as a test only and see if symptoms disappear ... if so then there is a short somewhere in the circuit
Don't burn the house down.
Oct 17, 2010 | Electrical Supplies
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Dimmer turns on/off 3 spotlights but they wont dim
Questions to answer so I can answer/resolve your problem:
1) Is this a rotary style dimmer?
2) Is it a toggle or slider type?
3) Is this on a 3-way circuit (that has 2 or more switches that can turn the lights on or off)
4) Is this on a single switch circuit?
5) Is this a brand new dimmer switch?
6) Is this an old dimmer switch?
7) Are the light bulbs in the spots regular incandesant or halogen bulbs?
8) Are the light bulbs in the spots CFL (compact flouresent lamps)?
With this information, I can tell you what the problem is:
If you answer "YES" to #1, and or #6 then the dimmer is faulty and should be replaced.
If you answer "YES" to #8, then you have the wrong dimmer for the bulb type, as CFL's require a specific dimmer type in order to dim them.
Please provide some more info and maybe we can help you figure out what's wrong.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Leviton Electrical Supplies
End of Run Dimmer Switch Installation
The store doesn't know what they are talking about. And I can't believe they told you to just keep switching wires. Hitting the wrong wires is an easy way to short the dimmer switch out. Take it back and go to Home Depot or Lowes and buy the same type switch you took out.
Mar 11, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
How to connect light switch
Nope, you have the wrong type of switch. The old one is what is called a 3-way switch. You need to purchase a replacement 3-way. The switch you currently have is a standard on/off switch and can not be used in that situation.
Dan
Dec 31, 2008 | Cooper Lighting Lighted Switch
Our handyman installed our Hunter Douglas Westside fan yesterday, and there is still a strong electrical burn smell everytime it's on. Should I be concerned? Thank you!
If you are controlling the fan speed with a wall type dimmer switch, the mechanical pull chain switch must be in the high speed position ONLY. If the pull chain switch is in the med or low position and you are using a dimmer type wall switch to control the speed you are burning the motor up. If this does not apply to your situation then it is possible that the fan is defective or maybe some packing material inadvertantly got inside the fan
Jul 02, 2008 | Hunter Heating & Cooling
GPS Logo
16 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
