Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Our pool vaccuum is not sucking up leaves but it is still moving about in the pool.
  • 640 Answers
It could be that you have low or no water pressure. If this is the case, you will need to adjust the pool cleaners flow. You will also want to check for obstructions in the wheel gears and axle or worn tire tread.
Posted on May 24, 2011
My robo kleen is moving but wont suck up the leaves and dirt
Possible blockage in the base where the leaves enter into the bag.
Jul 20, 2014 | Smartpool Robo Kleen
How come my aquabot turbo will not move or pump water?
Probably the drive belt came off the pulley or the belt broke. Similiar to a vaccuum
May 27, 2014 | Aquabot Turbo Robotic Pool Cleaner
MY POOL CLEANER SUCKS (LITERALLY) BUT DOES NOT MAKE THAT "CLICKING SOUND" AND DOES NOT MOVE. HAS IT SOMETHING TO DO WITH THE MOVEABLE PART. THERE ARE NO LEAVES IN THE PART ABOVE THE SKIRT AND...
Check your filter and pump basket for debris, also. Triple check the flaps. Debris is often the culprit with these pool cleaners when they malfunction. Check your return line water flow and make sure that it doesn't need to be adjusted.
Jan 18, 2011 | Universal Kreepy Krauly In-Ground Pool...
Not sucking debris into the bag. Moving around just fine, good speed, good coverage, but leaving the garbage behind. the bag also does not fill with water as it did before.
With these pool cleaners, there are several things that could be causing this problem. Make sure that your bag does not have any holes or lacerations in it that would cause the lack of suction. Make sure that your throat does not have debris stuck in it that could hinder cleaning. Check all connections to make sure that you have a tight seal.
Oct 20, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Pool vaccuum
are you filling the vacuum line with water before hooking it to the skimmer?
Jul 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
How do i get leaves out of the pool. I've tried using the vacuum but it clogs the filter. And my filter barley even sucks. whats the problem?
have you tried to run the vacum while backwashing the pool? If it helps suck up the leaves better then only do it a little at a time because you will taking water from the pool to go out on the ground.Just make sure you have a garden hose hand to replace any lost water...Are you using an earth or sand filter?
Jun 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
We have no suction in our vaccuum line. we have
some plumbing situations allow you to close a valve or two off in front of the pump...(suction side) check and make sure the obvious, (that the cleaner line is not closed)... next if its possible to shut down say the main drain and leave the skimmer open....doing this will allow the pump to pull from one source and therefore pull harder from that one source....therefore moving a vacuum.... the navigators are notorious for breaking down and needing special attention due to the multitude of moving parts in them
May 07, 2009 | Hayward Navigator Pool Cleaner
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
