Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
How do you take out the mesh filter of a classixx electronic dishwasher. The filter comes out easily but i cannot take out the mesh filter and tray to check if something is lodged in drain
    President:
  • 1,140 Answers
Just slip something flat and blunt under the edge and lever it out gently. A table knife will do it, but I generally use something wider, e.g. a scraper as pictured below.
Once you've removed the mesh screen, the second filter simply lifts out.
Apologies for the state of this washer. It's an old one I dismantled for instructional purposes!
Hope this helps. If you can't find the cause of the problem and need further assistance, please let me know.
Regards,
BElectric
Posted on Apr 09, 2011
The lower spray arm on my ASKO 1805 dishwasher has stopped turning, the dishes are still getting washed, so fluid still goes through the sytem, and drains at the end, the heater works. When turning, t
If the arm spins easily by hand, but won't spin when operating, that points to poor water delivery...
1) check the strainer. Not just the holey one you can see, but there might well be a very fine mesh filter under it ~ if so, remove it to clean it (it can appear clean, but still be clogged with transparent cellulose fibres). Try running the machine empty without the strainer/filter fitted. You should hear a difference if the filter was causing the problem.
2) you might have a weak impeller. After a while the plastic impeller on some machines just wears away, leaving insufficient fins to move the water, this can be accelerated by e.g. broken glass stuck in the pump. Impellers can also slip on the motor shaft; the motor's spinning but the impeller doesn't. This means removing the machine, turning it over and removing the pump for inspection...
Feb 13, 2015 | Asko 24 in. 1805 Built-in Dishwasher
Where`s the food filter catcher in a bosch classixx dishwasher
There i as a coarse food filter below the bottom basket which you twist to remove and a fine filter under the perforated plate in the base at the bottom you will have to remove the spray arm to get at it.
Oct 10, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Hi My Bosch Classixx Washing Machine wont Rinse or Spin Help! Washing Machine still has water in it!
you should have a cover that will come off ... on front bottom... then u will see a filter housing lid unscrew ...have towels a tray ready as water will come out.... check filter when out and see if theres any foreign objects inside ie money ect .. put back together hopefully your happy .........
Feb 27, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch Classixx Electronic not working
could be faulty door switch check that either board may be at fault but before this hapens is there power at board if not you may have had a flood internally tripping flood switch
Dec 26, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
513 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
