Question about Samsung SP42P2S Television
Lines I have distinct black lines across the screen that are only visible under certain circumstances usually when the picture is dark as opposed to a naturally bright programme, i e the lottery show! picture is being received via sky.is the set ready for the scrap or is a simple sollution at hand??
Have you try'd cleaning the screen, my friend had lines on his, he took the screen out, seperated it (2 pieces) and took his time cleaning it, seem'd 98% better when he finished
Posted on Nov 11, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Left side of screen is dark
When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
Feb 14, 2011 | Philips Televison & Video
During dark scenes or solid black picture, faint vertical lines can be seen across the entire screen. Have had tv for two months.
It is under warranty, have it check before warranty runs out ASAP because you do not want to have something else goes wrong either.
Dec 18, 2010 | Sony KDL46EX400 46 in. HD-Ready TV
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
Thin blue lines across screen more visible when picture is dark
blue crt is shorted you will need it replaced more than likely is NOT avail
Dec 01, 2009 | Televison & Video
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Eske told me to ask you
Thats usually related to the control board being defective when its across the entire screen, But check the ribbon connections on the control board
Jun 25, 2008 | Norcent Technologies PT4231 42 in....
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
White outlines in HD mode
is the screen control turned up to high if so you would see white lines on a dark picture
Oct 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Pictur
I have had a similar problem. Pictureres look like they are taken through a Venetial blind with white horizontal bands though I did get one with dark banding. It appears to have something to do with light levels. I took a few pics in a dark area with no flash and now it is working again...until it quits working again. Perhaps it is something to do with light level calibration? Whatever it is the problem is internal. If you are still under warranty, I highly recommend taking your camera in for repairs/replacement. Ours started acting up just after the warranty expired so no love for us.
Aug 07, 2007 | Kodak EasyShare C533 Digital Camera
Samsung SP42P2S Television Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
