Question about Hayward Navigator Pool Cleaner
Front and rear flaps are not flapping - Hayward Navigator Pool Cleaner
  • 640 Answers
It is possible that your pool cleaners shoes and/or wings have become worn. If you can see any visible wear and tear, you will need to replace them. If you are referring to the rear tension flap, there is a rear flap adjuster that you will need to loosen.
Posted on Apr 12, 2011
Locaation of the hydraulic roof reservoir on a audi a4 cabrio
BEHIND THE INNER COVER AT THE RIGHT OF THE TRUNK.U MUST TAKE OUT THE COVER..
1 - Flap for convertible roof compartment hinweis.gif Note
t The variable convertible roof compartment must be in the bottom position. t To remove flap for convertible roof compartment -1-, hinges -2- do not have to be removed. t Arrow points in direction of travel. q Bend flap for convertible roof compartment -1- on one side at hinge and disengage flap for convertible roof compartment -1- at hinges. q Fold down flap for convertible roof compartment -1-. q Disengage flap at hooks -4- (2x) by sliding it towards front. 2 - Hinge (2x) q Bend flap for convertible roof compartment -1- on one side at hinge and disengage flap for convertible roof compartment -1- at hinges. q Unscrew bolt -3-. q Disengage hinge -2- from body. 3 - Bolt (2x) 4 - Hook 5 - Variable convertible roof compartment
25573084-tnzdbwhiaswbtdy3r1p2vgzs-2-0.png THEN REMOVE THESE..
1 - Side trim (right-side) t Removing - Take out floor covering in luggage compartment. - Remove rear cross panel trim ? Chapter. - Remove trim for handle mounting ? Chapter. - Remove flap for convertible roof compartment ? Chapter. - Remove luggage compartment light ? Chapter. - Unfasten clip -2-. - Pull off side trim (right-side) -1- in direction of arrow. t Installing hinweis.gif Note
t Following installation, make sure seal is properly in position over trim. - Install trim in reverse order of removal. 2 - Clip
25573084-tnzdbwhiaswbtdy3r1p2vgzs-2-5.png UNDER THIS TRIM U WILL FIND THE MOTOR WITH THE TANK.USE HYDRAULIC OIL THAT U PUT AT THE STEERING RESERVOIR......BEWARE THE SAE OF THE OIL!!!!!
GOOD LUCK
Mar 15, 2015 | Audi A4 Cars & Trucks
Tip
VAG COM Fault Codes
ERROR CODE (DECIMAL) - CODE ERROR - ERROR CODE (OBD II) -The description ERRORS
00000 0000 O End
00001 0001 braking system control unit
00002 0002 gearbox control unit
00003 0003 control unit
00004 0004 control unit for engine gas-J659
00016 0010 Vers. electric space heater, rear right damper leg / defroster-V195
00017 0011 Vers. electric space heater, rear left footwell flap / defroster-V196
00018 0012 Executive electric cold air flap-V197
00019 0013 Executive damper motor warm air-V198
00020 0014 Executive electric Right flap and defroster vent-V199
00021 0015 Executive electric left flap and defroster vent-V200
00022 0016 Executive electric right hot air flap at the rear of the center console-V201
00023 0017 Executive electric left hot air flap at the rear of the center console-V202
00024 0018 Executive electric right cold air flap at the rear of the center console-V203
00025 0019 Executive electric left cold air flap at the rear of the center console-V204
00026 Executive 001A motor Right flap and defroster vent-V205
00027 Executive 001B motor left flap and defroster vent-V206
00028 001C Executive electric left bezel-V207
00029 001D Executive electric central bezel-V208
00030 Executive 001E motor right bezel-V209
00031 001F defrost key left rear glass-E299
00032 0020 defrost button the right rear window-E300
00033 0021 Control button front left deflector-E301
00034 0022 Control button front left center vent-E302
00035 0023 Control button front right center vent-E303
00036 0024 Control button right front baffle-E304
00037 0025 Key for adjustment of the temperature difference between the space for the legs and the upper part of the cabin-E305
00038 0026 Control button left rear deflector in the center console-E306
00039 0027 Control button right rear deflector in the center console-E307
00040 0028 lock button door opener inside-E318
00041 0029 Executive damper motor uniform air flow-V213
00042 Lamp 002A left hand fire-M43
00043 002B lamp right hand fire-M44
00044 002C Perform test 1 group of actuators
00045 002D Check Now 2 groups of actuators
00046 002E Electric retractable washer jets left headlight-V248
00047 002F motor sliding washer jets right headlight-V249
00048 0030 heat exchanger temperature sensor, left-G306
00049 0031 heat exchanger temperature sensor, right-G307
00050 0032 temperature sensor-G308 Evaporator
Full list of fault codes here
Car Manuals PDF
on Dec 20, 2016 | Cars & Trucks
How to fit Vauxhall Astra mud flaps?
maybe this will help good luck
Nov 17, 2014 | Cars & Trucks
VW fault codes
Hi there:
Are you scanned the PCM and have fault codes noted? Need description fault codes? Send us the specific fault codes that you find there.
Jul 01, 2012 | Volkswagen Cars & Trucks
Is there a specific envelope to use with the Imagerunner C3220 as the ones I have the flap is sealing.
None that I know of. Just make sure that the flap is facing down when using the bypass tray, I can't remember if the flap must go towards the rear or front. I believe, when you put an envelope in the bypass tray, you will also have to follow the prompts to make sure that you indicate on the display that an envelope is being used.
Jun 27, 2011 | Canon imageRUNNER C3220 Color Copier
Hi, I'm thinking of fitting rear mud flaps to my Citroen C4 picasso, just woundering if there any problems fitting them? Mike. (no citroen in dropdown)
fitting rear flaps is a simple job depending on the kit you buy......you may find the rear window gets dirtier with flaps fitted,due to spray being finer.(citroen is the same a puegeot)
Feb 15, 2011 | Renault Sportwagon Cars & Trucks
I need front and rear mud flap but i dont find anyplace to buy
Google MUDFLAPS and find some you think you will like. If you want OEM flaps, 93 is pretty old, so call the dealer.
Sep 02, 2010 | 1993 Suzuki Swift
2002 Honda Odyssey brake light replacement
open the rear hatch. Next to the brake light assembly, between it and the hatch there are two flap doors in the brake light trim. Take a small flat blade screwdriver and open these doors. The hinge side of the flap is nearest the hatch opening. when opened, the flaps will reveal two screws. Remove these. then wrap a flat blade screwdriver with some tape (protects the paint) and put the blade at the front outside corner of the brake light assembly. Pry gently rearward and a plastic spear point clip will release. With the assembly off, you can see how to twist out the bulb sockets and replace the bulbs. to replace, put the spear point clip in first, replace the screws, and close the flaps in the trim.
Mar 05, 2009 | 1997 Honda Odyssey
2003 Honda Odyssey Brake light replacement
open the rear hatch. Between the tail light housing and the rear hatch opening there is a trim strip with two flush fitted flap doors. Insert a small straight blade screwdriver into the small slot on the tail light side of the flap. Pry gently inboard and the small flap will open (the hinge side of the flap is on the side of the rear hatch opening.) Now you can remove the screws that hold the tail lamp assembly in place. Finally, there is still a "spear point" clip that fits into a socket near the front outboard corner of the assembly. Gently pry with a tape wrapped screwdriver (avoids scratches) and force the assembly straight back. The clip should release and free the assembly so you can change the bulb(s).
Jan 22, 2009 | 2003 Honda Odyssey
Hayward Navigator Pool Cleaner Logo
148 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
