Question about Exercise & Fitness
I have a Schwinn 6900i Treadmill that will run for about 4 minutes, then shut down showing an error code of E 9. What does that mean and how do I fix it?
wigginss80
  • 11 Answers
SOURCE: treadmill shuts off in about 60 seconds.
try calling the techinal number tell them the problem and they should be able to help u
Posted on Jul 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: schwinn 820 treadmill quit working in the middle
Loss signal: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
Testimonial: "very helpful thanks much, JW"
maxtreadmill
  • 832 Answers
SOURCE: Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Posted on Jun 13, 2010
SOURCE: I have a Kettler Atlantis
I have the same problem, it developed in the past few days. I've written to Kettler for assistance but not received a reply yet.
Posted on Oct 18, 2010
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Posted on Jan 18, 2011
My treadmill runs for 9 seconds and stops and shows E1
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Nov 24, 2014 | Triumph Academy Sports 400T Treadmill
What does a E2_C error code mean?
If the console doesn't receive a signal from the speed sensor, which is mounted on the back of the motor, the console stops sending power and displays an E2C error code.
You need someone to test voltage on the treadmill and determine if the power supply board, motor controller, or motor is bad.
You can have it repaired with "Sears Treadmill Repair" (even if you bought it somewhere else) calling them at 1-888-206-3131...
May 01, 2014 | Bowflex TC3000 Treadclimber
Tripping breaker that is built in to treadmill
you must isolate the problem. See if there some loose cable or touching with chassis. 3) test the input terminal motor for to see if there are faulty 4) test the output terminal in the control board, for to determine if are faulty. 5) filter capacitor can be shorte 6) power supply shorted.
Nov 13, 2013 | Schwinn 820 P Treadmill Silver Service...
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
Stops 5-10 min into exercise; trips breaker,
Dear Sir:
Thank you by your request. I hope everything is o.k
Now I will try to help you.
You have electrical-mechanical Problem:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact us with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or
some call it a console.
Thank you in advance, sincerely. God bless you.
If you need additional Help , please contact me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Bowflex Treadclimber
I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
Dear Sir:
I hope your are very well in union with your family.
I will help you inmediatel.
Please do the following:
1)
The amount of time required to shut down will progressively get shorter.
2)
the deck for wear too. If you want to go for a cheap fix try lubricating the walking
3)
case corrosion is causing.
If you need further assistance,please contact us.
E.CUADRA
Sep 27, 2011 | Exercise & Fitness
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Treadmill shuts off in about 60 seconds.
Jul 10, 2009 | Exercise & Fitness
Flashing light - TV shuts down
I will need the model number of your set in order to help you, but different models have different meanings for the error code. Your set is flashing an error code. Please respond to this and I will be able to help you with the problem.
Jun 15, 2008 | Sony Televison & Video
Exercise & Fitness Logo
159 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
