Question about Panasonic PT-AX200U Projector
PT-AX200U Bulb replaced 4 months ago Was on about
PT-AX200U Bulb replaced 4 months ago Was on about 15 minutes the heard a loud pop Standby on red and Lamp indicator flashes red Is bulb dead?
  • 442 Answers
Carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Posted on Apr 11, 2011
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
HOW DO I REST THE BULB LIFE ON MY Panasonic PT-AX200U
1. Press the MENU button to display the menu.
2. Select the OPTION menu and press the ENTER button.
3. Select LAMP RUNTIME.
4. Press and hold the ENTER button for approximately 3 seconds.
5. The confirmation screen will be displayed and select OK.
6. Press the POWER button to turn off projector for resetting the duration of the LAMP RUNTIME.
7. Confirm the duration of time in LAMP RUNTIME is reset to “0 H”.
Aug 05, 2010 | Panasonic PT-AX200U Projector
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
Hi:
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
Nov 04, 2009 | Panasonic PT-AX200U Projector
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Panasonic PT-AX200U Projector Logo
257 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
