There is a high pitched beeping that is coming from the rear of my 56" samsung dlp. when i turn it on everything operates as it should, except the picture never shows up, and it tries to turn itself on again and again. Then it shuts down and all 3 led lights on the front panel start blinking
  • foxfamily03 Aug 11, 2008
    Model # HLS5687W
  • 8,617 Answers
I would need the model number of your samsung in order to help you. Please reply to this same post when replying.
Posted on Aug 06, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ... > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from
High pitched sound coming from my Samsung DLP TV - Open Forum ... > Forums > Social > Open Forum
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
It is a DLP type set and if lamp comes on but other issues, I would first remove the lamp and look at the color wheel that faces it---looking for any broken or missing segments----often but not always the wheel will produce a fan like or high pitched sound as well.
Dec 03, 2012 | Samsung LENS-PRJ-ASSY K880-56/61 For...
Hlr5688w samsung dlp turns its self off
Two things to look at first:
Remove and inspect lamp to see if damaged or if picture is dim.
Second is listen for a fan like or high pitched sound or even a grinding sound---color wheel...
Those are the two most common issues here.
Oct 29, 2012 | Samsung HLR5688W 56" Rear Projection HDTV
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HDTV DLP high pitch wine, intermittent
Your color wheel is broken you can get one at
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
