Question about Craftsman Garden
Model # 917294261 tiller sat over the winter and now will not shift in to any gear I would also like to know where I could get a manual for this tiller thanks Paul
5 Suggested Answers
  • 69 Answers
SOURCE: I just want to know how to shift the gears
Check the Troybuilt website and get an owner's manual.
www.troybuilt.com
Posted on May 06, 2009
mwoodring1
  • 496 Answers
SOURCE: I have a Craftsman Rear
can you e-mail me the parts breakdown or the link to get it? this will help me help you fix your problem
if so you can email via fixya or to my email, madminibiker@gmail.com
thanks for helping me help you
M.Woodring
Posted on May 30, 2011
  • 207 Answers
SOURCE: how do i start. my
If you are having problems starting your tiller you shouldcheck 3 things, air, fuel and spark.
Fuel: check to make sure you are full of good quality fuel, try to start theengine several times then take out the spark plug and it should look wet. If its not wet then you aren't getting fuel into the engine.
Air: remove and clean the air filter with clean gasoline if its made offoam. If its made of paper then you should buy a new one from a localauto parts or hardware store.
Spark: disconnect the spark plug wire from the spark plug and hold thewire close to the engine block. Try to start the engine and watch for aspark to jump between the end of the wire and the engine block. If itdoesn't then either the wire is bad or the ignition coil is bad.
Posted on Jun 08, 2011
  • 1456 Answers
SOURCE: This is a Huskee tiller rear tine 2007
Hello
The shift assembly may be bent and couldn't move the clutch collar all the way over on the drive shaft.
You could hold the lever in but that would eventually bend the shifting fork in the transmission and it would then jump out of the groove in the shifting sleeve.
You should put new pins on the shifting fork and reinforce it so that it would not bend so easily.If that doesn't work then;
The shifting fork is not supposed to hold the shifting sleeve in gear. It is only supposed to slide the shifting mechanism and the detent spring and ball are supposed to do the holding work.Check if yours is doing otherwise
you will have to order a new detent spring part and a new detent ball part They cost $4.40 and that should solve the problem,you should also order a new shifting fork if yours has been bent. The new ones are a different design that has more reinforcement. It is a lot of work to tear into these so buy the new parts the first time.
Also check if there is a possible broken key where crankshaft meets gearbox.
Posted on Aug 15, 2011
What is winter mode
Andrew, in automatic equipped vehicles with winter/wet mode selection, I believe it starts vehicle off in a higher gear to prevent wheel spin. Your manual should explain what winter/wet mode is.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Winter Mode Button Volvo Forums Volvo Enthusiasts Forum
http://www.volvoxc.com/forums/archive/index.php/t-4.html
http://www.edmunds.com/driving-tips/the-basics-of-driving-a-volvo-in-the-snow.html
What is the exact function of the Winter and Wet feature on the gear shift...
Aug 20, 2016 | Cars & Trucks
How do I check gear oil
Owner's manual, no manual? try manualslib.com you will want it later anyway.
Apr 12, 2015 | Garden
Mtd turf power tiller
cannot find anything about a 420 tiller... need an actual model number please
Dec 24, 2013 | Garden
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Mtd Garden
Bike sat all winter starts but wont shift stalls if you put in gear
Check to see if it has a neutral safety switch at the kick stand. If it does and the switch thinks the stand is down it will die putting it into gear. This happened to a friends Yamaha V-max. We replaced the switch and all was good.
Feb 19, 2011 | Suzuki DL 650 V-Strom Motorcycles
Craftsman rototiller mod. # 917-294260 won't go into gear
try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
May 05, 2010 | Craftsman 8.50 Torque Rating Dual...
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Drive gear
You can call Sears Parts Direct @ (800) 252-1698
Monday - Friday 7am - 9pm Central time
Saturday - Sunday 9am - 7pm Central time
They will have the owners manual you need. Enjoy your tiller.
Apr 02, 2009 | Craftsman Rear Mount Tiller
Garden Logo
42 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
