Question about Kenmore Sewing Machines
Kenmore Sewing Machine Model 17920, the hand wheel, push pull cluth is very stiff. What can I do? What should I check?
bargainbox
  • 1388 Answers
SOURCE: Kenmore model 158-12392
It is a clutch issue.
If you can turn the handwheel manually and the motor belt is running OK but the needle will not move, you will need to check the clutch mechanism for the bobbin winder.
There are three ways for the clutch to engage, and as I do not know your machine, I offer all three for you to see which applies to yours.
Flick winder to the left to engage needle arm motion.......it may activate automatically when the winder is set to wind a new bobbin and de-activate the needle arm
or
there may be a small wheel inside the larger handwheel....tighten the inner wheel to engage needle arm...
or
the handwheel may have a push/pull action ....push in to activate the clutch, pull out for bobbin winding.
If there is any more you need to ask or update your info to refine the question, just post back here, or drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 14, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
louislevel_2
  • 374 Answers
SOURCE: bobbin threading
hi! well! everything is gonna be fine,make sure the thread was wine on clockwise rotation as shown on figures if this similar to your bobbins anyway this is just a sample how to set up bobbinsf1d210b.jpgthe thread is inserted on slot of bobbins case to acquire a tension tread. then hold bobbins on spindle while the needle of machine is on higher position.as shown on figures2320d1b.jpgthen inset this on shuttle hook case as shown on figures.d60bb50.jpgthen after bobbins was set up on shuttle case the thread of bobbins will hook up by the thread of needle by rotating the handwheel manually by your hand be sure the top thread was set up properly.just let me know if the procedure can help.
Posted on Mar 25, 2009
  • 96 Answers
SOURCE: Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
  • 371 Answers
SOURCE: viking sewing machine 940 needs spare parts
Certified Viking parts are only available from an authorized Husqvarna Viking dealer. However, there are some third party parts companies online. You should be able to find these using Google Search. However, I strongly recommend you have the machine serviced through an authorized Husqvarna Viking dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
Kenmore 19233 sewing machine. Then handwheel is broken, spins freely. Machine works perfectly otherwise. How do I remove the handwheel and replace it.
If the drive belt is not off or broken, then check hand-wheel setting. On some models the hand wheel can be pushed in (to engage) and pulled out (to disengage) for using bobbin winder. If it is disengaged the hand-wheel will spin freely. On older models there is a smaller wheel that has to be hand tightened in order to engage rest of machine. Hope this helps.
Nov 20, 2016 | Kenmore Sewing Machines
Please show a list of kenmore sewing machine manuals
This should be most of the Kenmore sewing machine manuals.
010
1020
1030
1040
1045
1050
1206
1230
1232
1240
1250
1300
1357
1430
1431
15/I649
15243
15343
15358
1625
1641
1660
17920
17921
17922
1940
1941
1947
19501
19502
200
38
385.17622
385.19000
385.101118
385.115518
385.11607
385.11703
385.12614
385.15202
385.15208
385.15243
385.15343
385.15358
385.15408
385.15512
385.15516
385.160201
385.16120200
385.162213
385.166551
385.16677
385.16765
385.19005
385.19365
519
ELITE
14
1500
15218
15616
15718
1600
1650
1651
1652
1654
1750
1791
18
385
385.17620
385.17624
385.17630
385.1 521 2
385.115418
385.12314
385.151082
385.15358
385.161302
385.19005
68
95
96
SWA/RS 10101
SWA/RS 11101
SWA/RS 12551
SWA/RS 12621
SWA/RS 14401
SWA/RS 14501
SWA/RS 14502
SWA/RS 14571
SWA/RS 14572
Oct 02, 2014 | Kenmore Sewing Machines
Hand wheel is siezing up on sewing machine
Sounds like it needs a good cleaning and oiling.
Jun 14, 2014 | Kenmore 744-08BH Mechanical Sewing Machine
It''s a SINGER sewing machine,,it's hand wheel run a slower and the next moment when i tried to sew a dress for me i found out dat it was'nt working well..i mean the hand wheel is stiff and not work but...
Has the clutch been disengaged to wind the bobbin? Pulling straight out on the handwheel on some machines will stop the needle from moving so that a bobbin can be attached and wound. If this is the case you simply push it straight back in. Also, on a computerized or electronic machine if the bobbin winding post is pushed right, the clutch will disengage. --Push it all the way left when you are done winding the bobbin to re-engage the clutch. If the problem is internal, like a slipped belt, you will need to have someone open up the machine to repair it. Hope you get it going again!
Apr 29, 2014 | Euro-Pro 9105 Computerized Sewing Machine
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
Machine will not turn over.Motor runs and cogged belt runs. Clutch?
Have you checked the cluth in the handwheel is not set for bobbin winding....it is a half turn of the centre wheel or a push pull action, not certain of this model.
Jul 31, 2009 | Singer 6510 Sewing Machine
Stitching Problem
adjust the stitch width to "0". If it still needs adjusting, somehting is sticking in the pattern mechanism
Mar 21, 2009 | Sewing Machines
Bobbin winder does not work on Model 17651
Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
You have to make sure that the hand wheel is engaged. To engage it, push it in, to disengage, pull it out.
Feb 03, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
83 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
