Question about Brother IntelliFax-2480C Fax
How do you open the paper tray? I have a brother intellifax-2480 c
    Novelist:
  • 129 Answers
Hi there!
The paper tray is the black plastic in the lower middle part of the machine that you have. To remove it from the machine do these steps:
-Using your right hand there's a handle at the bottom part of the tray you will be able to feel it. -Then Lift it up gently and just pull it out towards you. -Once the paper tray is out you will see the tray cover, there's a latch there that you can use to lift the tray cover up for you to reload the paper.
Hope this helps. rate if it works =)
Posted on Apr 09, 2011
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
I AM RECEIVING PAPER JAM AT MY BROTHERS INTELLIFAX-2820 THERE IS NO PAPER JAM AT ALL( I CHECKED IT COMPLETELY). AND FAX MACHINE KEEPS RUNING UNTIL I PUSH THE STOP KEY AND GIVES THE PAPER JAM MESSAGE.
Where is the paper jam?Jou can take the cartridge out and look if the sensor actuator is in it's plase.if you open the back door look for small pease of paper that might stay behind or a paper that did not go through otherwise take the paper tray out and look in the botom of the machine for sensors or peases of paper
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
How do i load the paper tray
Just open the paper tray cover towards you, replenish the paper, close the cover.
Dec 12, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How to change ink cartridge of intellifax 2480?
open from right side and just pull out old one and replace it!
Aug 26, 2009 | Brother IntelliFax-2480C Fax
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2480C Fax Logo
77 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
